I've installed Apticron a few days ago, but I'm not getting any emails even though I've edited /etc/apticron/apticron.conf and changed EMAIL= MY@MAIL.COM.
Does anyone have any ideas? I got Mailx installed and working properly and I'm able to send mails using Mailx, but for some reason I can't get it done with Apticron.
Fern Moss
  • 8,925
I had similar problem. The solution:
Edit this file
nano /etc/cron.d/apticron
and replace this line
10 * * * * root if test -x /usr/sbin/apticron; then /usr/sbin/apticron --cron; else true; fi
to like this:
10 * * * * root if test -x /usr/sbin/apticron; then /usr/sbin/apticron; else true; fi
I'm not sure why, but it works without
--cron
parameter.
Feriman
  • 208
In my case it did not work due to greylisting by recipient MX server.
A mail transfer agent (MTA) using greylisting will "temporarily reject" any email from a sender it does not recognize. If the mail is legitimate, the originating server will try again after a delay, and if sufficient time has elapsed, the email will be accepted.
So it is better to test that outgoing mail reaches your notification address before expecting apticron to work.
I used mail command as described in this answer.
NOTE: it might be a good idea to use some test service like mail-tester.com first in a hope to not get your dedicated IP instantly flagged by real e-mail provider like Google or the one that serves your recipient. It is just a thought though, I have no idea if such test services actually work that way, but it would be a logical assumption.
By reading auto-reply from mail I saw that my e-mail was not delivered with a mention of
Sorry, the service is currently unavailable. Please come back later
If you simply remove --cron parameter apticron will execute every hour instead of once per day. Which probably results in bypassing greylisting protection but does not fix real issues. E.g. my test e-mails ended up in spam.
Leeroy
