How can I enable hibernate on fresh installed system if it's possible.
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/nvme0n1p2 during installation
UUID=c14a936e-6c0f-4228-beec-c39bc515b157 /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/nvme0n1p1 during installation
UUID=1036-AA2D  /boot/efi       vfat    umask=0077      0       1
/swapfile                                 none            swap    sw              0       0
I tried In /ect/default/grub - GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=c14a936e-6c0f-4228-beec-c39bc515b157", but this is not working. Thanks.
zarok13
  • 43
To enable Hibernation in 20.04:
Increase swapfile size to match RAM size up to 8GB.
  • Check the swap that is in use:
    sudo swapon -s
  • If swap partition(s) are found:
    sudo swapoff -a
    sudo nano -Bw /etc/fstab
  • Add # before the UUID of the swap partition(s):
    # UUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX   none   swap    sw     0       0
  • Add a line for the swapfile, if one does not exist:
  • Create the swapfile:
    sudo fallocate -l XG /swapfile*
    where X is swapfile's size in GB:
    sudo mkswap /swapfile
    sudo chmod 0600 /swapfile
    sudo swapon /swapfile
  • Reboot:
    sudo reboot
Add resume location and offset to grub.cfg:
  • Edit /etc/default/grub:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX resume_offset=XXXXX"
  • Use UUID from root.
  • Use offset from:
    sudo filefrag -v /swapfile |grep " 0:"| awk '{print $4}'
  • Update GRUB:
    sudo update-grub
  • Test hibernation:
    sudo systemctl hibernate
A hibernate button can be added using GNOME extensions.
Note that there is a slight possibility of getting holes in a swapfile when creating it with fallocate. /var/log/syslog can be searched for the phrase swapon: swapfile has holes to ensure there will be no data loss.
A swap file can alternatively be created using dd:
sudo dd if=/dev/zero of=/swapfile bs=1G count=8
An error when using dd may overwrite your HDD.
C.S.Cameron
  • 20,530
  • 78
  • 125
