I can only hibernate via command. I tried several alternatives, but none of them work, from extensions to GNOME, passing through the swap configuration (it's working), to editing the grub configuration file. I can't enable hibernation through the options menu.
Asked
Active
Viewed 504 times
-2
I just created a keyboard shortcut to do it - you first disable the current super+H, then add new keyboard shortcut using "systemctl hibernate", then when you wish to hibernate, forget the menu - use super+H!
askubuntu.com/questions/1240123/
The MAJOR
- 479
