I tried to get drivers from realtech but this was not working, so I went to the ALSA project page https://www.alsa-project.org/wiki/Main_Page and attempted to install alsa-lib-1.2.4 and alsa-utils-1.2.4 as instructed by the README. Now when ever i try to use apt i get a broken pip error.
$ sudo apt --fix-broken install
Reading package lists... Done Building dependency tree
Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: linux-libc-dev:i386 The following NEW packages will be installed: linux-libc-dev:i386 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. 24 not fully installed or removed. Need to get 0 B/1,138 kB of archives. After this operation, 5,965 kB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 233231 files and directories currently installed.) Preparing to unpack .../linux-libc-dev_5.4.0-52.57_i386.deb ... Unpacking linux-libc-dev:i386 (5.4.0-52.57) ... dpkg: error processing archive /var/cache/apt/archives/linux-libc-dev_5.4.0-52.57_i386.deb (--unpack): trying to overwrite shared '/usr/include/sound/asequencer.h', which is different from other instances of package linux-libc-dev:i386 dpkg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/linux-libc-dev_5.4.0-52.57_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
