After a recent kernel upgrade, I lost the use of my Wacom tablet (Wacom Intuos Pro Pen and Touch Tablet, Large). I used to use the tablet together with Xournal++ to take notes for my online lectures. From September up until ~October 15, the tablet and pen worked perfectly. I would be able to map the tablet to a single monitor/display. I use three monitors/displays: the laptop screen, one connected via the USB-C port, and the third via the HDMI port). The tablet was mapped to the one connected to the HDMI port.
Now, since the latest kernel upgrade (5.4.0-52 64-bit kernel on Ubuntu 20.04 LTS, GNOME version 3.36.3), I am unable to map the tablet to a single monitor/display (any of the three). As a result, and since I use three monitors/displays, all that I write is stretched three times in the horizontal directions making it impossible to write or draw anything that would make sense to my students.
I have tried several times the different options in the Settings > Wacom Tablet > Tablet menu. I even tried all possible combinations but no success.
Any and all help is appreciated. Please let me know if you need additional information about the setup to help me debug.
EDIT: The selected answer works. To help check the name of the device I used xinput and looked for the line with the line with stylus in it.
Also, to get the coordinates for the offset, or use the display name to map directly to the desired display, I used xrandr. More information may be found here.
Juan Antonio
  • 1,602
I found a bug regarding this Problem here.
the Problem seems to be with the display output names. For me the Workaround with setting the output manually with worked:
xsetwacom --set "Wacom Intuos Pro S Pen stylus" MapToOutput 1920x1080+0+0
Well, I actually had to change the numbers around a bit, because, the aspect ratio and position of my desired display are different. But as a temporary workaround, while they are working on a solution this is OK for me.
the general idea with the numbers at the end is: <width of projection>+<height of projection>+<offset x>+<offset y> for me it was 3400x1440+3840+0
When you are using a different tablet, you might get a message, like this: Cannot find device 'Wacom Intuos Pro S Pen stylus'.. I was lucky enough, that I just had to switch out the S for an M (so the string was Wacom Intuos Pro M Pen stylus for me) but I don't really know where to look for the value you have to use here, when using a different product.
I hope it helps.
EDT: I forgot: I'm using Ubuntu 20.04.1 LTS (with kernel version 5.4.0-52-generic). I'm not so sure on whether or not it's the same for other distros, but yeah, still hope, that I at least notched you in the right direction.
Wr4thon
  • 186
