I've found on google a way to install Windows 10 without an USB/DVD by copying the installer to a second partition and make it bootable. I've managed to do that and update my grub but when I'm trying to boot into the new partition this error comes up: This is not a bootable disk please insert a bootable floppy.
Is there any way to install Windows 10 using this way or I should give up? Notice that I can't buy an USB at the moment.
Here's my grub menu-entry for the windows setup:
menuentry 'Windows Recovery Environment (on /dev/sda4)' --class windows --class os $menuentry_id_option 'osprober-chain-592C85254E2CD0B7' {
    insmod part_msdos
    insmod ntfs
    set root='hd0,msdos4'
    if [ x$feature_platform_search_hint = xy ]; then
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos4 --hint-efi=hd0,msdos4 --hint-baremetal=ahci0,msdos4  592C85254E2CD0B7
    else
      search --no-floppy --fs-uuid --set=root 592C85254E2CD0B7
    fi
    parttool ${root} hidden-
    drivemap -s (hd0) ${root}
    chainloader +1
Installing Windows 10 without USB using Ubuntu, Step by Step
This step by step has been created from information provided by the OP, @Marcel Alexandru.
  • Backup the Target drive.
  • Create a 6GB NTFS partition on the hard drive and extract the Windows ISO to it.
  • Create a 20GB, or larger, NTFS partition on the hard drive for the Windows Installation.
  • Open Disks, (Gnome-Disks), and note Device, (/dev/sdx), and UUID of the Windows ISO extract partition.
  • For msdos partition table, copy the menuentry given in this question to /etc/grub.d/40-custom/*
  • Add ntldr /bootmgr as a line below chainloader +1
  • Edit menuentry, changing sda4 to sdax, msdos4 to msdosx (4 places), and 592C85254E2CD0B7 to UUID, (3 places), to suit step 4 above.
  • Run sudo update grub confirm that ntldr /bootmgr appears in grub.cfg.
  • Boot the computer into the newly created menuentry and install Windows into it's new partition.
  • Reinstall Ubuntu if desired, the GRUB bootloader will have been replaced with the Windows bootloader.
*Note from the OP: You don't have to reinstall Ubuntu to fix the grub loader. You can boot in the Ubuntu Live USB, open a terminal and open Boot Repair using the boot-repair command. If it's not available you can install it using the following commands:
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
For more information about repairing your Grub follow this link: https://help.ubuntu.com/community/Boot-Repair.
*For gpt partition table, copy the following menuentry to /etc/grub.d/40-custom/:
menuentry 'Windows Recovery Environment (on /dev/sdc1)' --class windows --class os $menuentry_id_option 'osprober-chain-5642BC722509341F' {
    insmod part_gpt
    insmod ntfs
    set root='hd0,gpt1'
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 --hint-efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1  5642BC722509341F
    else
      search --no-floppy --fs-uuid --set=root 5642BC722509341F
    fi
    chainloader +1
    ntldr /bootmgr
This method can also be adjusted to make a Windows installer USB or to add a Windows installer to a multiboot USB.
Limitations
Windows 10 has limitations with respect to partition tables and boot modes.
I was able to install Legacy mode Windows to a drive with a MSDOS partition table.
I was able to install UEFI mode Windows to a drive with a GPT partition table.
I was not able to install Legacy mode Windows to a drive with a GPT partition table.
I was not able to install UEFI mode Windows to a drive with a GPT partition table and Legacy mode Ubuntu.
There may be workarounds that are outside the scope of this answer.
C.S.Cameron
  • 20,530
  • 78
  • 125
