I opened another thread here some weeks ago Internet sites are loading slowly sometimes with Firefox and Chromium.
The solution helped to improve the loading speed in general, but I still have the (minor) issue that sporadically websites take some seconds to start loading. In chromium I then see the message "Resolve Host" (Host auflösen in German) on the left bottom. That's why I think it could be due a DNS issue, but all tests we did in the other thread show that everything seems to be fine. I tried the Ubuntustudio live image and it seems to work without issues there, although I only could test it with Firefox which is not showing me that message.
My PC is connected via LAN to a Fritzbox repeater (1750E) and that one is connected by WLAN to another one which finally connects to the Fritzbox by WLAN. All routers are meshed and all my other devices works fine.
The issue occurs more often after diretly starting the PC. If website A has problems with resolving the host name and it finally loads after some seconds, the second time I load the site it works immediately which may be points to a DNS cache issue (?). I even get it sometimes when opening my router fritz.box site.
My Ubuntu version is: No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.1 LTS Release: 20.04 Codename: focal
Some more info:
    System:
      Host: marco-MS-7817 Kernel: 5.4.0-47-lowlatency x86_64 bits: 64
      Desktop: Xfce 4.14.2 Distro: Ubuntu 20.04.1 LTS (Focal Fossa)
    Machine:
      Type: Desktop Mobo: MSI model: H81M-E34 (MS-7817) v: 3.0
      serial: <superuser/root required> BIOS: American Megatrends v: 17.5
      date: 03/30/2015
    CPU:
      Topology: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP
      L2 cache: 6144 KiB
      Speed: 3200 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 3200 2: 3200
      3: 3200 4: 3200
    Graphics:
      Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
      driver: i915 v: kernel
      Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
      resolution: 1920x1080~60Hz
      OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
      v: 4.5 Mesa 20.0.8
    Audio:
      Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
      driver: snd_hda_intel
      Device-2: BEHRINGER UMC204HD 192k type: USB driver: snd-usb-audio
      Device-3: AKAI Professional M.I. type: USB
      driver: hid-generic,snd-usb-audio,usbhid
      Sound Server: ALSA v: k5.4.0-47-lowlatency
    Network:
      Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
      driver: r8169
      IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: d8:cb:8a:e8:e9:99
    Drives:
      Local Storage: total: 523.08 GiB used: 159.23 GiB (30.4%)
      ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
      ID-2: /dev/sdb type: USB vendor: Samsung model: Portable SSD T5
      ID-3: /dev/sdc type: USB vendor: SanDisk model: Ultra size: 57.30 GiB
    Partition:
      ID-1: / size: 36.41 GiB used: 12.45 GiB (34.2%) fs: ext4 dev: /dev/sda1
      ID-2: /home size: 184.23 GiB used: 66.59 GiB (36.1%) fs: ext4
      dev: /dev/sda6
      ID-3: swap-1 size: 7.45 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
    Sensors:
      System Temperatures: cpu: 41.0 C mobo: N/A
      Fan Speeds (RPM): N/A
    Info:
      Processes: 260 Uptime: 20m Memory: 7.23 GiB used: 3.97 GiB (54.9%)
      Shell: bash inxi: 3.0.38
edit:
 sudo lshw -C network
[sudo] Passwort für marco:
  *-network
       Beschreibung: Ethernet interface
       Produkt: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       Hersteller: Realtek Semiconductor Co., Ltd.
       Physische ID: 0
       Bus-Informationen: pci@0000:02:00.0
       Logischer Name: enp2s0
       Version: 0c
       Seriennummer: d8:cb:8a:e8:e9:99
       Größe: 1Gbit/s
       Kapazität: 1Gbit/s
       Breite: 64 bits
       Takt: 33MHz
       Fähigkeiten: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       Konfiguration: autonegotiation=on broadcast=yes driver=r8169 duplex=full firmware=rtl8168g-2_0.0.1 02/06/13 ip=192.168.178.23 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
       Ressourcen: irq:18 ioport:e000(Größe=256) memory:f7d00000-f7d00fff memory:f0000000-f0003fff
ip a
1: lo: &lt;LOOPBACK,UP,LOWER_UP&gt; mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: enp2s0: &lt;BROADCAST,MULTICAST,UP,LOWER_UP&gt; mtu 1492 qdisc fq_codel state UP group default qlen 1000
    link/ether d8:cb:8a:e8:e9:99 brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.23/24 brd 192.168.178.255 scope global dynamic noprefixroute enp2s0
       valid_lft 862605sec preferred_lft 862605sec
@tracepath
tracepath www.google.com
 1?: [LOCALHOST]                      pmtu 1492
 1:  fritz.box                                             7.938ms
 1:  wpad.fritz.box                                        1.830ms
 2:  x4db53c5a.dyn.telefonica.de                           2.639ms pmtu 1492
 2:  loopback1.0003.acln.02.fra.de.net.telefonica.de      14.828ms
 3:  bundle-ether30.0004.dbrx.02.fra.de.net.telefonica.de  16.144ms
 4:  bundle-ether1.0004.prrx.02.fra.de.net.telefonica.de  15.519ms
 5:  72.14.213.76                                         16.803ms asymm 10
 6:  keine Antwort
 7:  keine Antwort
 8:  keine Antwort
 9:  keine Antwort
10:  keine Antwort
11:  keine Antwort
12:  keine Antwort
13:  keine Antwort
14:  keine Antwort
15:  keine Antwort
16:  keine Antwort
17:  keine Antwort
18:  keine Antwort
19:  keine Antwort
20:  keine Antwort
21:  keine Antwort
22:  keine Antwort
23:  keine Antwort
24:  keine Antwort
25:  keine Antwort
26:  keine Antwort
27:  keine Antwort
28:  keine Antwort
29:  keine Antwort
30:  keine Antwort
     Too many hops: pmtu 1492
     Resume: pmtu 1492
systemd-resolve --status
Global
       LLMNR setting: no
MulticastDNS setting: no
  DNSOverTLS setting: no
      DNSSEC setting: no
    DNSSEC supported: no
          DNS Domain: fritz.box
          DNSSEC NTA: 10.in-addr.arpa
                      16.172.in-addr.arpa
                      168.192.in-addr.arpa
                      17.172.in-addr.arpa
                      18.172.in-addr.arpa
                      19.172.in-addr.arpa
                      20.172.in-addr.arpa
                      21.172.in-addr.arpa
                      22.172.in-addr.arpa
                      23.172.in-addr.arpa
                      24.172.in-addr.arpa
                      25.172.in-addr.arpa
                      26.172.in-addr.arpa
                      27.172.in-addr.arpa
                      28.172.in-addr.arpa
                      29.172.in-addr.arpa
                      30.172.in-addr.arpa
                      31.172.in-addr.arpa
                      corp
                      d.f.ip6.arpa
                      home
                      internal
                      intranet
                      lan
                      local
                      private
                      test
Link 2 (enp2s0)
      Current Scopes: DNS
DefaultRoute setting: yes
       LLMNR setting: yes
      DNSSEC setting: no
  Current DNS Server: 192.168.178.1
         DNS Servers: 192.168.178.1
          DNS Domain: ~.
                      fritz.box
lines 25-47/47 (END)
                      31.172.in-addr.arpa
                      corp
                      d.f.ip6.arpa
                      home
                      internal
                      intranet
                      lan
                      local
                      private
                      test
Link 2 (enp2s0)
      Current Scopes: DNS
       LLMNR setting: yes
      DNSSEC setting: no
          DNS Domain: ~.
                      fritz.box
ls -al /etc/resolv.conf
lrwxrwxrwx 1 root root 29 Sep 27 22:10 /etc/resolv.conf -&gt; ../run/resolvconf/resolv.conf
 cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
# 127.0.0.53 is the systemd-resolved stub resolver.
# run &quot;systemd-resolve --status&quot; to see details about the actual nameservers.
nameserver 127.0.0.53
search fritz.box
dpkg -l *dnsmasq* | grep ii
ii  dnsmasq-base     2.80-1.1ubuntu1 amd64        Small caching DNS proxy and DHCP/TFTP server
marco
  • 113
