12
since I've upgraded to 20.04 last month, I keep hearing a double beep X6 times (like an alarm clock) each day exactly at 12:00.
I didn't install any alarm programs recently and I'm pretty sure the sound comes from the OS because it is muted when I turn off the system sound.
Did anyone experience something similar? I really don't have a clue on where to start looking...
Michael S
  • 121
The sound is probably a sound-only notification for some event in one of your calendars. It is played by evolution data server (even if you don't use Evolution but just GNOME Calendar). The sounds can be turned off in Evolution 3.43.1 and higher (unreleased at the time of writing) in the Settings or via:
gsettings set org.gnome.evolution-data-server.calendar notify-enable-audio false
If you use an older Evolution version and cannot update, then a rather crude workaround is to remove the audio file, i.e., sudo rm /usr/share/sounds/freedesktop/stereo/alarm-clock-elapsed.oga. Be aware that this file is part of the sound-theme-freedesktop package and so it will be be restored whenever the package is reinstalled.
See https://unix.stackexchange.com/a/620061/501515 for further instructions and a general approach for debugging this.
