so my Ubuntu 20.04 is behaving weirdly, i am unable to launch Terminal. Whenever i click on the icon it gives me the loading animation and then nothing happens. I didn't even installed anything special that will cause something like this. Help me with this. Thanks !!
- 343
if you can open the .bashrc with a text application like 'Text Editor' edit it as advised by Thiago Rider Augusto in I messed up my .bashrc
- Click in Ubuntu icon (the first bottom in side menu).
- Write gedit
- Open Text Editor clicking in its icon.
- Click in Open.
- In the list, write: ~/.bashrc
- Enter
- Clean your failing .bashrc file.
- Save and you can open terminal again.
second option is to default your .bashrc -
ADVISABLE YOU MAKE A COPY OF THIS FILE BEFORE REPLACING IT - (just make a copy, rename a backup when you go to that file in the file manager in /etc/skel/)
see if you can switch TTY with CTRL-ALT-F4, login and run this below
Finally, use the following command in your terminal to replace the >~/.bashrc with a fresh copy,
/bin/cp /etc/skel/.bashrc ~/
It will replace your corrupt ~/.bashrc with a fresh one. After that, you >need to source the ~/.bashrc so that the change takes place immediately, >write in the terminal,
. ~/.bashrc
or,
source ~/.bashrc
as mentioned by souravc default .bashrc
then CTRL-ALT-F1 to return -
- 46
Posting because I had the same issue. Have you updated Python recently??
I tried a bunch of things everywhere. Here's what I eventually found that worked. It turned out when I updated python, it updated what gnome-terminal was set to. Here's what ya do:
Ctrl + Alt + F3, this will open a terminal
login
type sudo vim /usr/bin/gnome-terminal substitute vim for whatever editor you have if needed
check the comment at the top does it read #!/usr/bin/python3? If so, change it to the version you're using of python.
I was updating to 3.9 so I changed it to #!/usr/bin/python3.9. This fixed the issue and allowed me to open the terminal. Update it to whichever version you're using.
The issue was caused by when I updated python, for some reason it changed the gnome-terminal to just generically be python, instead of the python version I was actually using.
- 107
