I had been using Lubuntu for quite a long period of time. I am having a moderate hardware in my computer. The older versions of Lubuntu were just fine. But the latest 20.04.1 LTS seems to have some sort of a bug as may a times it goes into some sort of memory overload.
I find the HDD usage light on my PC staying on continuously, then the PC gets slow and then ultimately it freezes. I do not have any options at that time than to restart my pc. It is quite annoying in the sense that I have to redo many of the works which were lost in this process.
It is not that I do heavy processes. I had seen this issue usually when my browser is on and at the same time suppose I am working on a document file (just writing texts on to .odt files or so) or writing a C program in gedit.( Just an example of the situation).
My pc configuration is as shown:
abhishek@abhishek:~$ neofetch
.-/+oossssoo+/-. abhishek@abhishek
`:+ssssssssssssssssss+:` -----------------
-+ssssssssssssssssssyyssss+- OS: Ubuntu 20.04.1 LTS x86_64
.ossssssssssssssssssdMMMNysssso. Kernel: 5.4.0-47-generic
/ssssssssssshdmmNNmmyNMMMMhssssss/ Uptime: 3 mins
+ssssssssshmydMMMMMMMNddddyssssssss+ Packages: 2001 (dpkg)
/sssssssshNMMMyhhyyyyhmNMMMNhssssssss/ Shell: bash 5.0.17
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Resolution: 1280x1024
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ DE: LXQt
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM: Openbox
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM Theme: Lubuntu Arc
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ Theme: Arc-Darker [GTK3]
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Icons: Adwaita [GTK3]
/sssssssshNMMMyhhyyyyhdNMMMNhssssssss/ Terminal: qterminal
+sssssssssdmydMMMMMMMMddddyssssssss+ Terminal Font: Ubuntu Mono 14
/ssssssssssshdmNNNNmyNMMMMhssssss/ CPU: Intel Core 2 Duo E7200 (2) @ 2.364GHz
.ossssssssssssssssssdMMMNysssso. GPU: Intel 82945G/GZ
-+sssssssssssssssssyyyssss+- Memory: 443MiB / 2984MiB
.-/+oossssoo+/-.
Apparently I found that the same issue is faced by few others as well. Here as well as here.
Now in the second question it is said that the system hangs in every 10-15 secs, but that is not the case in my system. The freeze occurs randomly. And for this answer here to the second question which is different from that of mine, the answer does not explain in detail what each command is supposed to do and the commands to revert back if incase it does not work.
I feel that this a bug in the os itself. What are the ways to overcome it?
Edit:
Below is the output on running free -h
abhishek@abhishek:~$ free -h
total used free shared buff/cache available
Mem: 2.9Gi 671Mi 1.3Gi 141Mi 997Mi 2.0Gi
Swap: 0B 0B 0B
However on running grep -i swap /etc/fstab I got no output.
abhishek@abhishek:~$ grep -i swap /etc/fstab
