Last week, fonts in Ubuntu 20.04 have grown a lot bigger. How do I revert them to the old size? I can't find desktop icon font size in settings or tweak tool.
xiota
  • 5,038
Christine
  • 481
you can try this out to change font size on ubuntu 20.04:
  1. Option One:
    • open settings.
    • go to universal access.
    • check if Large Text is on - if it is, turn it off.
  2. Option Two:
    • use gnome tweaks.
    • use sudo apt install gnome-tweaks to install the tool.
    • after installation open the app.
    • then change the scaling factor value to 1.0 (wich is the default value).
  3. Option Three:
    • using terminal to increase or decrease text size.
    • gsettings set org.gnome.desktop.interface text-scaling-factor (value) - value 1 its the default value.
    • gsettings reset org.gnome.desktop.interface text-scaling-factor - to reset the value to his default size.
    • this link found helpful to solve the problem How do I change the font DPI settings? (added after edit).
johncli
  • 329
For me the problem was that suddenly GTK applications(*) - on Wayland - started consulting Xrdb for the Xft.dpi setting. Due to some old shenanigans, I had the ~/.Xresources set on my system with a Xft.dpi value set to 120 - which was the real problem, and once I removed that file - it went back to how it was supposed to look, with a native DPI of 96:
$ xrdb -q | grep -i xft
Xft.antialias:  1
Xft.dpi:        96
Xft.hinting:    1
Xft.hintstyle:  hintslight
Xft.rgba:       rgb
Another thing that may cause similar behavior is if you have the xsettingsd daemon running and providing Xft settings, and that has a DPI set incorrectly - check ~/.xsettingsd and see what "DPI" settings you have there. Note that ~/.xsettingsd has the settings in "mibi-DPI", i.e. the DPI value time 1024, so 96 DPI is "98304".
*) But not all of them? Eclipse was still looking fine while other SWT applications exhibited the same behavior as GTK apps.
Guss
  • 3,775
