19
I am very new to linux. On my laptop I have a multiboot with Windows 10 and Ubuntu 20.04 on the same disk.
The problem is when I suspend to RAM and then wake it up by pressing the power button, the disk starts running, however the screen remains black. I tried logging in blind (the screen was still black and I tried using the keyboard), opening terminal and typing reboot and that works.
Looking for solution, I found this thread. One of the solutions were to sudoedit /etc/default/grub and add nouveau.modeset=0 to the line that says GRUB_CMDLINE_LINUX. Apparently it's an nvidia driver bug. Except I have AMD CPU with Radeon graphics, so this isn't my case, right?
Another solution was installing xscreensaver, which I already had installed. I also checked the possibility of having the swap partition encrypted which also wasn't the case.
Is it some problem with AMD drivers? Can you please help me find a solution?
My hardware is HP Probook 455 G7 with AMD Ryzen 3 4300U, AMD Radeon Graphics and 16 GB RAM. I am running 64bit Ubuntu 20.04.1 LTS, GNOME 3.36.3 and kernel 5.4.0-47
nice-guy
  • 191
6 Answers6
Seems like an amdgpu issue, which is resolved in kernel 5.8. As the current kernel is 5.4, you should do:
sudo apt install linux-generic-hwe-20.04-edge
I found the answer here: Is there a kernel 5.8 ppa for ubuntu 20.04?
Epo Nym
  • 136
I stumbled across this post and have an Nvidia card. The sudo ubuntu-drivers autoinstall fixed the issue for me.
So for anyone with Nvidia cards, it seems that clicking on 'additional drivers' doesn't have what an autoinstall does.
Update: Yes the above fixed if one has Nivida and same blank screen after suspend, yet found issue remain if logged in, and suspend resumed as normal if I logged out first then suspend. Then resume normal. Strange.
For debugging I use to have separate home partition and swap partition and all this now since found do not need seaparate partitions. Anyway found another post suggested:
... sudo apt install gnome-screensaver ...
Now No more blank screen after suspend resume. So an easy fix:
... sudo ubuntu-drivers autoinstall && apt install gnome-screensaver ...
p.s. I think it is to do with 'no-more' separate swap and root partitions, and current Nvidia video drivers. not technical so just saying. Thank you all at ask Ubuntu, posting this for others. Happy puppy :-)
On my Legion 5 pro with NVIDIA GeForce RTX 3050Ti this solution works for me (It fixes both issues: change brightness and wake up after suspend)
  1. Select discrete card in BIOS setup
  2. Install drivers
  1. Open Software & Updates application on tab Additional drivers select nvidia-driver-470, it does not works with nvidia-driver-510
Restart system
  1. Go to /sys/class/backlight and get available brightness acpi
> ls /sys/class/backlight
nvidia_0    # <- if you have here nvidia_0 then it's ok
  1. Create backlight rule
sudo nano /etc/udev/rules.d/backlight.rules
add this content
ACTION=="add", SUBSYSTEM=="backlight", KERNEL=="nvidia_0", GROUP="video", MODE="0664"
RUN+="/bin/chgrp video /sys/class/backlight/nvidia_0/brightness"
RUN+="/bin/chmod g+w /sys/class/backlight/nvidia_0/brightness"
Save file
  1. Update grub
sudo nano /etc/default/grub
update line with GRUB_CMDLINE_LINUX_DEFAULT
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=nvidia_0 nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1"
save file
sudo update-grub
Restart system
The problem can come from GPU drivers. Try this one, then restart your laptop:
Walllter
  • 109
I've noticed that I have issues coming back from suspend if the video driver and line 11 of /etc/default/grub do not correlate to the following:
if using the NVIDIA proprietary driver go into /etc/default/grub and change line 11 to GRUB_CMDLINE_LINUX=""
if using the X.org driver go into /etc/default/grub and change line 11 to GRUB_CMDLINE_LINUX="nouveau.modeset=0"
After making the change depending on which driver I'm using it has resolved the issue.
and... You need to check the settings of the NVIDIA driver!!! Mine was on balanced and nothing helped until I changed to the FullPower-NVIDIA or the Powersaving Xorg driver...
