sudo apt install openjdk-8-jre-headless
Reading package lists... Done
Building dependency tree
openjdk-8-jre-headless : Depends: ca-certificates-java but it is not installable
Depends: java-common (>= 0.28) but it is not installable
tanmay@tan:/usr/bin$ sudo apt update
Hit:1 http://packages.microsoft.com/repos/vscode stable InRelease
Hit:2 https://download.docker.com/linux/ubuntu focal InRelease
Hit:3 http://ppa.launchpad.net/openjdk-r/ppa/ubuntu focal InRelease
Hit:4 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:5 http://ppa.launchpad.net/rock-core/qt4/ubuntu focal InRelease
Hit:6 http://ppa.launchpad.net/webupd8team/y-ppa-manager/ubuntu focal InRelease
Hit:7 http://dl.openfoam.org/ubuntu focal InRelease
All packages are up to date.
W: Skipping acquire of configured file 'stable/source/Sources' as repository 'https://download.docker.com/linux/ubuntu focal InRelease' does not seem to provide it (sources.list entry misspelt?)
W: Skipping acquire of configured file 'main/source/Sources' as repository 'http://dl.openfoam.org/ubuntu focal InRelease' does not seem to provide it (sources.list entry misspelt?)
Unable to install in 20.04. New to ubuntu. Thanks in advance.
Unpacking JRE ... Starting Installer ... Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/tanmay/{name removed}.12871.dir/jre/lib/amd64/libnet.so: libgconf-2.so.4: cannot open shared object file: No such file or directory at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary1(ClassLoader.java:1965) at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1890) at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1872) at java.lang.Runtime.loadLibrary0(Runtime.java:849) at java.lang.System.loadLibrary(System.java:1088) at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:67) at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:47) at java.security.AccessController.doPrivileged(Native Method) at sun.nio.ch.Util.load(Util.java:485) at sun.nio.ch.IOUtil.<clinit>(IOUtil.java:351) at sun.nio.ch.Util.<clinit>(Util.java:48) at sun.nio.ch.FileChannelImpl.<clinit>(FileChannelImpl.java:1204) at java.io.RandomAccessFile.getChannel(RandomAccessFile.java:278) at com.install4j.runtime.launcher.util.SingleInstance.check(SingleInstance.java:74) at com.install4j.runtime.launcher.util.SingleInstance.checkForCurrentLauncher(SingleInstance.java:31) at com.install4j.runtime.launcher.UnixLauncher.checkSingleInstance(UnixLauncher.java:91) at com.install4j.runtime.launcher.UnixLauncher.main(UnixLauncher.java:60)
Followed How do I restore the default repositories?, and trying to install *.sh file. Got the error mentioned above. This is the first time i am using askubuntu. I will try to address my query in a better syntax and semantics.
