I have an HP laptop (Hp 15R250Tu) with Realtek RTL8723BE WIFI card after upgrading the kernel to 5.4.0-45 generic. The WIFI connection keeps getting Dropped after some time like 15-20 minutes with message Activation of network connection failed and then it won't connect no matter what I do expect the only option left is to restart. Sometimes it won't at all show Wifi option in menu just the Airplane mode is active on toggling it to off the Bluetooth gets on this keeps on going but WIFI doesn't show up. Even I opened up the laptop to swap the antenna wire to(aux port/no.2) and to my surprise there is no second antenna port at all given in wifi card. so all and all the antenna depends on just single connection and this leaves no room to swap the antenna port. Further I tried Live boot strange to see but even the live boot is not showing wireless option I tried both Linux mint and Manjaro.This issue is persistent from many months tried several solutions Larry finger git hub branch, Dkms but not successful.
Questions Referred
- realtek-rtl8723be-wifi-drivers-not-working-after-upgrading-to-5-4-0-37
- realtek-rtl8723be-wi-fi-incredibly-weak
- how-to-permanently-install-wifi-driver-realtek-8723de-in-ubuntu-18-04
- wifi-signal-is-weak-in-ubuntu-18-04-with-rtl8723be
- wifi-networks-not-found-ubuntu-18-04-with-rtl8723be
- how-do-i-get-a-realtek-rtl8723be-wireless-card-to-work
- unable-to-connect-wifi-ubuntu-14-04-lts-hp-pavilion-network-driver-rtl8723be
Output from terminal
uname -r
5.4.0-45-generic
dkms status
fwts-efi-runtime-dkms, 18.03.00, 5.4.0-42-generic, x86_64: installed
fwts-efi-runtime-dkms, 18.03.00, 5.4.0-45-generic, x86_64: installed
dmesg | grep -i rtl
[ 4.788890] r8169 0000:04:00.0 eth0: RTL8106e, 5c:b9:01:f9:a3:62, XID 449, IRQ 93
[ 23.139091] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 23.140085] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 23.140088] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 23.479730] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 23.479782] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 23.479798] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 24.298711] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 61.320543] RTL8208 Fast Ethernet r8169-400:00: attached PHY driver [RTL8208 Fast Ethernet] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
[ 2294.012286] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 2294.014441] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 2294.014458] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 2294.014544] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 2294.102350] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 2294.102409] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 2294.995873] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 2314.407626] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 2314.409564] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 2314.409578] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 2314.409671] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 2314.409809] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 2314.409860] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 2315.249387] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[ 2322.273698] RTL8208 Fast Ethernet r8169-400:00: attached PHY driver [RTL8208 Fast Ethernet] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
[ 2335.384040] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[ 2335.385039] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 2335.385044] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[ 2335.540042] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[ 2335.540104] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 2335.540138] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[ 2335.868705] RTL8208 Fast Ethernet r8169-400:00: attached PHY driver [RTL8208 Fast Ethernet] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
[ 2336.393069] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
rfkill list
3: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
iwconfig
enp4s0 no wireless extensions.
enp0s29u1u2 no wireless extensions.
lo no wireless extensions.
modinfro rtl8723be
filename: /lib/modules/5.4.0-45-generic/kernel/drivers/net/wireless/realtek/rtlwifi/rtl8723be/rtl8723be.ko
firmware: rtlwifi/rtl8723befw_36.bin
firmware: rtlwifi/rtl8723befw.bin
description: Realtek 8723BE 802.11n PCI wireless
license: GPL
author: Realtek WlanFAE <wlanfae@realtek.com>
author: PageHe <page_he@realsil.com.cn>
srcversion: 775916BF393FDE315ED454E
alias: pci:v000010ECd0000B723sv*sd*bc*sc*i*
depends: rtlwifi,rtl8723-common,rtl_pci,btcoexist,mac80211
journalctl link here
dmesg link here
lspci here
wireless info txt here
EDIT 1:
dkms status
fwts-efi-runtime-dkms, 18.03.00, 5.4.0-47-generic, x86_64: installed
sudo lshw -C network
*-generic DISABLED
description: Wireless interface
product: Illegal Vendor ID
vendor: Illegal Vendor ID
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: ff
serial: c4:8e:8f:af:99:7b
width: 32 bits
clock: 66MHz
capabilities: bus_master vga_palette cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8723be driverversion=5.4.0-47-generic firmware=N/A latency=255 link=no maxlatency=255 mingnt=255 multicast=yes wireless=IEEE 802.11
resources: irq:17 ioport:2000(size=256) memory:90700000-90703fff
*-network
description: Ethernet interface
product: RTL810xE PCI Express Fast Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 07
serial: 5c:b9:01:f9:a3:62
capacity: 100Mbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII
resources: irq:19 ioport:1000(size=256) memory:90500000-90500fff memory:90400000-90403fff
