I'm trying to update my dev environment (a VMWare virtual machine) from 16.04 LTS to 20.04 LTS. The update to 18.04 seemed to have run fine but now when I boot I get a kernel panic and then it says at the end "Machine halted".
I tried to follow the solutions outlined in this similar issue:
Kernel panic and unable to boot Ubuntu 16.04 after updating
Observations:
  • If entering grub menu and selecting the old kernel, I can boot to desktop just fine
  • The outlined solutions do not work, for example:
sudo update-initramfs -u -k 4.15.0-117-generic && sudo update-grub
where the kernel version is the new one from 18.04 version. By not working I mean the booting still fails and the command gives and output:
I: The initramfs will attempt to resume from /dev/sda5
I: UUID=....
I: Set the RESUME variable to override this
(while the boot partition is actually /dev/sda1)
Anyway not a linux pro and no I'm pretty lost how to solve this problem?
EDIT 1:
Related issue:
Ubuntu 13.10, kernel still 3.8.0-31-generic
But the proposed solution to not help as everything is installed correctly (according to apt):
abc@Lubuntu-16-04:~$ sudo apt-get install linux-generic
Reading package lists... Done
Building dependency tree
linux-generic is already the newest version (4.15.0.117.104).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Plus some additional information:
abc@Lubuntu-16-04:~$ uname -sr
Linux 4.4.0-189-generic
abc@Lubuntu-16-04:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.5 LTS
Release:    18.04
Codename:   bionic
A screenshot of the kernel panic, can't copy the text:
Kernel Panic
beginner_
  • 161
If you're trying to go from Lubuntu 16.04 LTS to 20.04, you should re-install.
Lubuntu 18.04 LTS was the last Lubuntu release that used the LXDE desktop. If you check the release notes of any later LXQt release, such as Lubuntu 20.04 LTS, you'll note the following warning
Note, due to the extensive changes required for the shift in desktop environments, the Lubuntu team does not support upgrading from 18.04 or below to any greater release. Doing so will result in a broken system. If you are on 18.04 or below and would like to upgrade, please do a fresh install.
https://lubuntu.me/focal-released/ https://lubuntu.me/focal-1-released/
Lubuntu LXDE desktops require re-install to switch to a modern LXQt desktop.
Yes the Lubuntu team wrote notes on the 18.04 (last LXDE) to 18.10 (first LXQt), but in testing users were all having problems where they had made changes to the defaults, such that the LXDE to LXQt notes were never published (you'll have to use a search engine to find them) and the LXDE to LXQt change is unsupported without re-install. Also note those notes were never updated to allow for 18.04 to later releases (eg. 18.04 to 20.04 upgrades).
Given you've stated you want to move to Lubuntu 20.04 LTS, you should upgrade your install via re-install.
guiverc
  • 33,561
