22
I need to enable scroll lock so I can toggle lights on my keyboard. This works on Arch.Funny thing it doesn't work on Ubuntu.
http://linuxtechie.wordpress.com/2008/04/07/getting-scroll-lock-to-work-in-ubuntu/
$ xmodmap -e ‘add mod3 = Scroll_Lock’
xmodmap:  unknown command on line commandline:1
xmodmap:  unable to open file 'mod3' for reading
xmodmap:  unable to open file '=' for reading
xmodmap:  unable to open file 'Scroll_Lock’' for reading
xmodmap:  4 errors encountered, aborting.
Jorge Castro
  • 73,717
xmodmap -e 'add mod3 = Scroll_Lock'
(Note the difference in the single-quotes!)
Copy this and paste it in a terminal.
Then the error will no longer occur.
I have used this command successfully on my Ubuntu 12.04 system.
user74063
  • 377
Or you can switch the lights with these:
On:
xset led named "Scroll Lock"
Off:
xset -led named "Scroll Lock"
Works on Ubuntu 12.04 x86 for my SpeedLink illuminated keyboard (SL-6453-SSV-A).
Eliah Kagan
  • 119,640
SenorGrande
  • 261
Found the permanent way after a long night up with lots of half baked solutions.
# backup your symbols file
sudo cp /usr/share/X11/xkb/symbols/us{,.distribution}
Add the following line in the xkb_symbols "basic" { section. do not worry if that second line is not there, it is only there for some languages and was not there for us on my system.
    modifier_map Mod3   { Scroll_Lock }; <==<< Add this line
    include "level3(ralt_switch)" <==<< before this line
You may have to do the same in your other layouts if you switch between languages
Also, there is a cache where xkb layouts live. You should clear it before restarting your X server to check the new keyboard symbol file(s).
sudo dpkg-reconfigure xkb-data
Pykler
  • 687
If you just modify the
/usr/share/X11/xkb/symbols/pc
you should use a command like
sudo gedit /usr/share/X11/xkb/symbols/pc
and add the line
inside the
xkb_symbols "pc105" {
Remember to restart or log out-log in. It's enough.
Abri5
Guilherme
  • 146
