I can get the list of packages using command:
dpkg-query --show --showformat='${Package;-50}\t${Installed-Size}\n' | sort -k 2 -n | grep -v deinstall | awk '{printf "%.3f MB \t %s\n", $2/(1024), $1}'
and now I would like to know whether the particular package is critical for the system or not. If the package is no longer required then I will delete them. I want free up root space.
Hacke
  • 428
  • 13
Deleting packages is rarely an effective way to free up space in the root filesystem. Packages are small and numerous.
  • Look for large (runaway) logfiles in /var/log. Those can free up a lot of space quickly! Remember that a runaway log is merely a symptom of a problem that still needs to be investigated and fixed.
  • Look for large personal files in your /home. A movie or two takes up a lot of storage. Occasionally, folks who have a separate /home discover that it failed to mount and all their data is in the root filesystem instead.
  • Run baobab (also known as Disk Usage Analyzer) to search for large files on your root filesystem. It's included with every stock install of Ubuntu Desktop -- use your Desktop Search to find it. If you are on a Server instead of a desktop, here are some good techniques to find big files using du
Here's one easy, safe way to determine is a package is system-critical:
apt remove --simulate <package_name>
  • The --simulate option means that the removal WON'T actually take place. An additional protection is omitting sudo.
Read the output: If only the package is removed (and perhaps a few dependencies), then it is likely safe to remove.
However, if the list of proposed removals includes one of these red flags, then DON'T do it for real:
  1. The list is lengthy
  2. The list includes applications that you use
  3. The list includes one of the desktop meta-packages (ubuntu-desktop, kubuntu-desktop, etc.)
  4. The list includes the apt, dpkg, python3, or python3-minimal packages (removing those would destroy your package manager)
user535733
  • 68,493
Try
sudo apt-get autoremove
This command removes packages that were installed by other packages and are no longer needed.
Also try
sudo apt-get autoclean
This command removes .deb files for packages that are no longer installed on your system. Depending on your installation habits, removing these files from /var/cache/apt/archives may regain a significant amount of diskspace.
To get information on a package use
apt-cache show <package_name>
This command shows the description of package <package_name> and other relevant information including version, size, dependencies and conflicts.
For further info read this HowTo on AptGet
If you want to use dpkg try
dpkg -I package.deb
for information of a specific package
