I am trying to learn gradle build.
I followed these instructions on gradle.org.
To verify it i am issuing command.
gradle -v
I get this output:
Command 'gradle' not found, but can be installed with:
sudo apt install gradle
But after issuing this command from the installation link
$ export PATH=$PATH:/opt/gradle/gradle-4.10.2/bin
the above command shows gradle version in my computer.
But the problem is once I close the terminal and issue the command I get the error command not found, and once again if I issue the export PATH... command, then the gradle command starts working.
So how do I add this path permanently so I can issue the gradle command from anywhere?
