I recently installed Ubuntu 20.04 on Razer Blade Pro 17, but I am having a problem with the laptop constantly being put to sleep after I put it to sleep in the first place.
I can boot into Ubuntu, and OS works normally. I can put it to sleep/close a lid, and everything goes fine still. However, when I awake it again, it will work for around 15s and then go to sleep again.
I have tried playing around with settings even switching off Automatic Suspend option in the settings, but with no luck.
Update:
After digging through logs, I've found that ACPI throws this error around the time system goes to sleep:
ACPI Error: AE_NOT_EXIST, While executing method \_WAK (20190816/hwesleep-47)
balbok
  • 191
Found a solution on this github repo, which also contains some other useful resources for Linux on Razer laptops.
Solution is to add button.lid_init_state=open to GRUB_CMDLINE_LINUX_DEFAULT argument in /etc/default/grub and then sudo update-grub.
To get rid of ACPI error, you might also want to add acpi=on or acpi=hybrid to the same boot options. This can solve an issue with touchpad not responding.
balbok
  • 191
