I installed droidcam by following the steps given here. However after installing the sound stopped working. The speakers don't work, neither do headphone. I uninstalled it and it started working again. Any help on how to use droidcam and be able to keep the sound working for other applications?
It seems that the problem occurs after I run the following command as given in the above link. The sound works fine just fine prior to this command.
sudo ./install-sound
Is there any way to reverse its effects once I am done with Droidcam?
