previously I had tried these methods 1 2, then found out under /dev/sda1 says Available 0 use 100% mounted on / . I don't know how to use ubuntu, but I'm guessing they are related, could someone help me? I recently installed Ubuntu 18.04
Asked
Active
Viewed 642 times
they were indeed related, after freeing up space, magically my password wasn't wrong. to free up space I used root on recovery mode, write command to see where the disk usage is coming from:
du -a / | sort -nr | head -n 10
in my case it was folders, I made sure of what was inside:
sudo ls -1ha /path/
deleted it with:
sudo rm -r -f /path/
