Gconf and Dconf settings
A lot of QT applications will query GNOME's configuration databases for the icon theme settings. Under some circumstances there might be a discrepancy between the icon theme in use and the corresponding GNOME setting.
So to change the icons you might have to set the corresponding Gconf and Dconf keys first. You can do so with the following commands (replace Faenza-Dark with your icon theme of choice):
gsettings set org.gnome.desktop.interface icon-theme Faenza-Dark
and
gconftool-2 --type=string --set "/desktop/gnome/interface/icon_theme" "Faenza-Dark"
It might take a relog to see the changes.
The theme names correspond with their basename in the filesystem. It doesn't matter where the theme is located. Be it /usr/share/icons/AskUbuntu, ~/.icons/AskUbuntu or ~/.local/share/icons/AskUbuntu, in each case the Gconf/Dconf name will be AskUbuntu.
Note
This fix will not work for all QT applications out there. Some, e.g. Clementine, have turned out to be very resilient and - as much as you might try - just won't change their icon theme. That's likely due to issues with how these applications detect the system theme. In other cases (e.g. Skype) the icons might be hard-coded into the binary and impossible to change.
References
https://github.com/linuxmint/Cinnamon/issues/1793
http://forums.fedoraforum.org/showpost.php?p=1453006&postcount=19
http://slackbuilds.org/repository/11.0/desktop/tango-icon-theme/
How to change desktop theme periodically
