While updating the Ubuntu 20.04, I am getting the following error:
/var/cache/apt/archives/libsystemd0_245.4-4ubuntu3.2_amd64.deb
The system was running 19.10, and was recently upgraded to 20.04.
The result of sudo apt autoremove is:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libsystemd0 : Breaks: libsystemd0:i386 (!= 245.4-4ubuntu3.1) but 245.4-4ubuntu3.2 is installed
libsystemd0:i386 : Breaks: libsystemd0 (!= 245.4-4ubuntu3.2) but 245.4-4ubuntu3.1 is installed
libudev1 : Breaks: libudev1:i386 (!= 245.4-4ubuntu3.1) but 245.4-4ubuntu3.2 is installed
libudev1:i386 : Breaks: libudev1 (!= 245.4-4ubuntu3.2) but 245.4-4ubuntu3.1 is installed
systemd : Depends: libsystemd0 (= 245.4-4ubuntu3.2) but 245.4-4ubuntu3.1 is installed
udev : Depends: libudev1 (= 245.4-4ubuntu3.2) but 245.4-4ubuntu3.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
The result of sudo apt install libsystemd0 is:
libudev1 : Breaks: libudev1:i386 (!= 245.4-4ubuntu3.1) but 245.4-4ubuntu3.2 is to be installed
libudev1:i386 : Breaks: libudev1 (!= 245.4-4ubuntu3.2) but 245.4-4ubuntu3.1 is to be installed
udev : Depends: libudev1 (= 245.4-4ubuntu3.2) but 245.4-4ubuntu3.1 is to be installed
