systemd is using 100% continually ... here is top
top - 19:47:09 up 13 min,  1 user,  load average: 3.26, 2.62, 1.69
Tasks: 306 total,   4 running, 294 sleeping,   0 stopped,   8 zombie
%Cpu(s): 35.5 us, 12.6 sy,  0.0 ni, 51.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :  11858.2 total,   5183.4 free,   3433.2 used,   3241.6 buff/cache
MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   7913.7 avail Mem
PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
  1 root      20   0  268660 110536   8532 R 100.0   0.9  11:39.36 systemd
772 message+  20   0   10988   6768   4116 R  46.0   0.1   5:16.01 dbus-daemon
259 root      19  -1  496536 327492 325464 S  16.8   2.7   2:16.95 systemd-journal
796 syslog    20   0  221104   5832   4052 S  13.9   0.0   1:38.00 rsyslogd
804 root      20   0  103380  93880   7784 S  13.1   0.8   1:34.41 systemd-logind
 18 root      20   0       0      0      0 S   0.7   0.0   0:00.55 ksoftirqd/1
1733 root 20 0 352968 130376 83760 S 0.7 1.1 0:25.47 Xorg
1916 ava 20 0 4008000 272576 117864 S 0.7 2.2 0:32.40 gnome-shell
3877 ava 20 0 2629148 269672 162688 S 0.7 2.2 0:09.53 Web Content
here is the system log
 sudo tail -n 100 /var/log/syslog
Aug 13 19:46:11 kiev systemd[1]: Failed to start Process error reports when automatic reporting is enabled.
Aug 13 19:46:11 kiev systemd[1]: apport-autoreport.service: Start request repeated too quickly.
Aug 13 19:46:11 kiev systemd[1]: apport-autoreport.service: Failed with result 'start-limit-hit'.
here is some of dmesg
[    3.942656] systemd[1]: Inserted module 'autofs4'
[    4.005635] systemd[1]: systemd 246-2ubuntu1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    4.025381] systemd[1]: Detected architecture x86-64.
[    4.046020] systemd[1]: Set hostname to <kiev>.
[    4.132974] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[    4.137916] systemd[1]: /lib/systemd/system/dbus.service:12: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    4.164397] systemd[1]: /lib/systemd/system/plymouth-start.service:17: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    4.193000] systemd[1]: /lib/systemd/system/gdm.service:30: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
this happened after my last system update ... same after reboot and/or another system update ... any ideas ?
ubuntu 20.04
As a temporary workaround: Delete all files under /var/crash/ It is not a long or even medium term solution, but better then nothing for a start.
edit file /usr/lib/systemd/system/apport-autoreport.path
#  PathExistsGlob=/var/crash/*.crash  #  <-- old bad comment it out
PathChangedGlob=/var/crash/*.crash # good new replaces above line
save then issue
sudo systemctl daemon-reload
for details see https://bugs.launchpad.net/ubuntu/+source/apport/+bug/1891657
Here we are months later after this issue has been resolved below is contents from a healthy normal box ( Ubuntu 20.04 as of 20210812 )
cat /usr/lib/systemd/system/apport-autoreport.path
[Unit] Description=Process error reports when automatic reporting is enabled (file watch) ConditionPathExists=/var/lib/apport/autoreport
[Path] PathExistsGlob=/var/crash/*.crash
[Install] WantedBy=paths.target
old obsolete solution ______________
just shut off the out of control service apport
sudo systemctl disable apport-autoreport
#  sudo apt-get purge apport    #  avoid it works yet is too heavy handed
sudo apt-get purge apport-noui
then after a reboot systemd cpu usage was normal yet
tracker-miner-fs
was using 100% cpu even after another reboot so I issued
gsettings set org.freedesktop.Tracker.Miner.Files crawling-interval -2
gsettings set org.freedesktop.Tracker.Miner.Files enable-monitors false
echo y | LANG=en tracker reset --hard
now all is well
I had a similar issue just recently. The "apport" service failed to start. This issue was caused by modifying the "/etc/cron.daily" directory. The "apport" file must have executable permission (at least) to the root. Fixed it. There are no issues now.
The command can verify the solution: $> systemctl -t service
All active services, including the "apport.service" should show up as "loaded active exited."
The Lesson Learned is "Do not change the original file permissions." Removing or moving that file to another location would have the same effect.
This issue and the solution are valid for Ubuntu Server 24.04 LTS.
References
systemctl man page for Noble Numbat LTS
AliTan
