I have installed Ubuntu 16.04.6 version on Lenovo IdeaPad 3 14IIL05, After installation laptop's keyboard, touchpad and WiFi are not working. I reinstalled xserver-xorg-input-all package and also updated the kernel version but still facing the same issue. I have executed xinput command, touchpad and keyboard are not detecting.
Asked
Active
Viewed 2,238 times
You can go to "Software & Updates" and then additional drivers tab to check which drivers are needed to be installed.
Or you can use this command to get a list of available drivers:
sudo ubuntu-drivers devices
You can install them manually, or you can use:
sudo ubuntu-drivers autoinstall
mokazemi
- 71
In order to fix the touchpad:
sudo gedit /etc/default/grub
Replace line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" with GRUB_CMDLINE_LINUX_DEFAULT="pci=nocrs quiet splash"
Save file /etc/default/grub
Execute sudo update-grub
Reboot.
This is commented here:
ChanganAuto
- 1
- 8
- 15
- 23
amarintj1986
- 31
