I tried upgrading my Ubuntu from 11.10 to the new 12.04 and I had to force my computer off because it froze. I thought I had to restart the upgrade process, but apparently it somehow finished upgrading. Unfortunately, now I can't log in.
There is a black terminal-like screen asking for an "Ubuntu Username" and "password". I keep keying in my computer name and password in different ways, but it keeps saying it's invalid.
I don't want to restart my artworks that I worked days on.
How can I get on the new Ubuntu without losing my stuff?
(note my laptop doesn't use f# keys)
mickmackusa
  • 852
  • 20
you have a couple questions in there, so let's break this down one at a time:
  1. Try logging in again:
    Just to cover all your bases, have you checked to see if caps lock, etc. might be turned on when entering your password?
  2. Accessing your files:
    Boot from a LiveCD and select "Try Ubuntu" (don't install). You can "rescue" your files by mounting the disk, and copying them to an external harddrive or a usb key. Depending on the permissions of your home folder you may need to use sudo to copy things over. (e.g., open a terminal window and enter gksu nautilus to open a file browser with sudo privileges)
  3. Restoring/Reinstalling the system:
    Once you have all your files safely backed up you can try fixing the system (although, I'm not sure how in your case. You can try booting into a recovery shell as root, and change the user password see HERE). Or, with your files safe, you could just reinstall.
amc
  • 7,292
