After upgrade to Ubuntu 20.04 LTS, some Gnome extensions can't work. I try to delete and re-install them through Chrome/Firefox, but the download action can't start as expected. How to debug the issue? Thanks!
Asked
Active
Viewed 618 times
Did you upgrade from Ubuntu 19.04? If not, then your issues may be the result of "skipping" versions. You can read up on it here. In which case you should backup your data and do a fresh install of Ubuntu 20.04 and it should work properly.
If you're interested in why "skipping" versions is a problem, read the first answer to this.
siya
- 31
