Recently I installed Ubuntu 20.04 on my Acer Swift 3 laptop.
The internal microphone doesn't seem to work. Input Device drop-down menu is empty in Sound settings. But the external mic from earphones is detected and works fine.
Here are a few outputs that might be helpful,
reyansh@acer:~$ cat /proc/asound/card0/codec* | grep Codec
Codec: Conexant Generic
Codec: Intel Icelake HDMI
Multimedia audio controller output from lspci -v command,
00:1f.3 Multimedia audio controller: Intel Corporation Smart Sound Technology Audio Controller (rev 30)
Subsystem: Acer Incorporated [ALI] Smart Sound Technology Audio Controller
Flags: bus master, fast devsel, latency 32, IRQ 164
Memory at 601d160000 (64-bit, non-prefetchable) [size=16K]
Memory at 601d000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci
Last few lines from /etc/modprobe.d/alsa-base.conf,
#Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-2
#options snd-hda-intel model=auto
options snd-hda-intel dmic_detect=0
I tried this but no luck. Any kind of help will be greatly appreciated. Thanks!
Edit 1: Output of sudo hdajacksensetest -a (without external mic)
Pin 0x16 (Black Headphone, Right side): present = No
Pin 0x17 (Internal Speaker, Rear side): present = No
Pin 0x18 (Not connected): present = No
Pin 0x19 (Black Mic, Right side): present = No
Pin 0x1a (Not connected): present = No
Pin 0x1d (Not connected): present = No
Pin 0x1e (Not connected): present = No
Pin 0x1f (Not connected): present = No
Pin 0x21 (Not connected): present = No
Pin 0x26 (Not connected): present = No
Pin 0x27 (Not connected): present = No
Edit 2:
Output of modprobe --show-depends snd_hda_intel
reyansh@acer:~/Documents/Keys$ modprobe --show-depends snd_hda_intel
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soundcore.ko
install /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
insmod /lib/modules/5.4.0-42-generic/kernel/sound/core/snd-timer.ko
install /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
insmod /lib/modules/5.4.0-42-generic/kernel/sound/core/snd-hwdep.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/hda/snd-hda-core.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/pci/hda/snd-hda-codec.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/hda/snd-intel-dspcfg.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/pci/hda/snd-hda-intel.ko model=auto dmic_detect=0 patch=hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw,hda-jack-retask.fw
Output of modprobe --show-depends snd_sof_pci
reyansh@acer:~/Documents/Keys$ modprobe --show-depends snd_sof_pci
insmod /lib/modules/5.4.0-42-generic/kernel/sound/core/snd-pcm-dmaengine.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/ac97_bus.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/core/snd-compress.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/snd-soc-core.ko
insmod /lib/modules/5.4.0-42-generic/kernel/drivers/leds/trigger/ledtrig-audio.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/snd-soc-acpi.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/intel/common/snd-soc-acpi-intel-match.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/hda/ext/snd-hda-ext-core.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/xtensa/snd-sof-xtensa-dsp.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/snd-sof.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/intel/snd-sof-intel-ipc.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/intel/snd-sof-intel-byt.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/intel/snd-sof-intel-hda.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/codecs/snd-soc-hdac-hda.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/intel/snd-sof-intel-hda-common.ko
insmod /lib/modules/5.4.0-42-generic/kernel/sound/soc/sof/snd-sof-pci.ko
Output of journalctl -b -k -p3
-- Logs begin at Wed 2020-04-01 22:53:42 IST, end at Tue 2020-08-04 12:10:16 IST. --
Aug 04 06:44:01 acer kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.DGPV], AE_NOT_FOUND (20190816/psargs-330)
Aug 04 06:44:01 acer kernel: ACPI Error: Aborting method \_SB.PCI0.RP05.PCRP._ON due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
Aug 04 06:44:01 acer kernel: Initramfs unpacking failed: Decoding failed
Aug 04 12:03:52 acer kernel: snd_hda_codec_generic hdaudioC0D0: The codec is being used, can't reconfigure.
Aug 04 12:04:29 acer kernel: snd_hda_codec_generic hdaudioC0D0: The codec is being used, can't reconfigure.
Aug 04 12:07:04 acer kernel: snd_hda_codec_generic hdaudioC0D0: The codec is being used, can't reconfigure.
Aug 04 12:07:10 acer kernel: snd_hda_codec_generic hdaudioC0D0: The codec is being used, can't reconfigure.
Output Devices in pavucontrol
Input Devices in pavucontrol
AlsaMixer Configuration when earphones with mic is not plugged in.
