32
At this time, I am unable to update from Disco 19.04 to Focal 20.04. I have read several current questions that have been closed, referring to some really old questions. I have already read all the 8 year old threads and followed those instructions. They were helpful but they don't solve my problem. I have read all the questions suggested to me while typing this. Please don't close my thread and refer to the old ones as they do not resolve this issue, which is NEW (as in, it has been 8 years already since those questions were answered and they don't address my problem).
After trouble shooting and replacing "archive" with "old-releases" and eliminating all the third party packages from the source list, I am able to "apt update" and "apt upgrade" and the system is up to date.
I have tried "full-upgrade", "dist-upgrade" and everything else I can think of. All now say:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I already fixed all the error messages I was getting using all the suggestions in all the other threads I have already read.
When I run "do-release-upgrade", I get the following output:
Checking for a new Ubuntu release
Your Ubuntu release is not supported anymore.
For upgrade information, please visit: http://www.ubuntu.com/releaseendoflife
Get:1 Upgrade tool signature [1,554 B] Get:2 Upgrade tool [1,337 kB] Fetched 1,338 kB in 0s (0 B/s) authenticate 'focal.tar.gz' against 'focal.tar.gz.gpg' extracting 'focal.tar.gz' Reading cache Checking package manager Can not upgrade An upgrade from 'disco' to 'focal' is not supported with this tool.
When I user the Software Upgrade graphical tool, I get the following:
Can not upgrade: An upgrade from 'disco' to 'focal' is not supported with this tool.
This computer has many users and much software loaded and I cannot do a fresh install. First, I don't know how to do so while saving all the users, files and programs and second, I foresee a nightmare scenario of a blown up computer with everything gone.
If I can upgrade from 19.04 to 19.10, I have been unable to figure it out. I am pretty sure it can't be done since 19.04 is no longer supported.
In case it matters, my disk is encrypted.
Please, please, please someone tell me there is a way to get from 19.04 to 20.04 without a fresh install, saving all my users, data and programs! I would be absolutely shocked if there is no way to upgrade simply because I missed the update deadline. If not, I will be forced to buy a new computer!
jokerdino
  • 41,732
KingWm
  • 491
This is the only instruction which helped me: Upgrading End of Life (EOL) Ubuntu Version Ubuntu 19.04
Quoting from the above link:
~# nano /etc/apt/sources.list
I got stuck trying to update php 7.2 to 7.4 because my Digital Ocean server was on an older version of Ubuntu.
If I tried to update my release I'd get the following
# do-release-upgrade
Please install all available updates for your release before upgrading.
When attempting to update my packages with apt-get update I would get these types of errors.
Err:5 http://mirrors.digitalocean.com/ubuntu disco Release
  404  Not Found [IP: 172.67.168.253 80
E: The repository 'http://mirrors.digitalocean.com/ubuntu disco Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default.
These occur because my Ubuntu version is not only out of date but at its end of life so updating Ubuntu to a newer version.will require me to update my repositories.
Digital Ocean uses its own mirrors for repositories so there is a little more work there in figuring out which ones to use.
What version of Ubuntu am I on?
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 19.04
Release:        19.04
Codename:       disco
What repositories are being used?
Example repoistory on Digital Ocean Ubuntu 19.04
deb http://mirrors.digitalocean.com/ubuntu/ disco main restricted
Let's first get our current Ubuntu version up to date
To make the server update the files, we had to edit the /etc/apt/sources.list with working repository locations.
To goal here, on this Digital Ocean server is to update the urls they use for the repositories with ones you that will have the files you need for your update
We want to replace this urls
with
old-releases.ubuntu.com
This command will work
sudo sed -i -e 's/mirrors.digitalocean.com/old-releases.ubuntu.com/g'
Now
sudo apt-get update
will work!
Let's keep going
sudo apt-get upgrade -y
sudo apt-get dist-upgrade
Try to upgrade Ubuntu on the command line.
We are still unable to upgrade via do-release-upgrade
Can not upgrade
Frack!
So now I have my current outdated version of Ubuntu up to date, but I can't upgrade to the next version using do-release-upgrade
You can try to upgrade manually.
First go to https://changelogs.ubuntu.com/meta-release and scroll down to the release you want to upgrade to.
For example if you want to upgrade to Ubuntu 19.10 Eoan scroll to you find the url to the UpgradeTool
UpgradeTool: http://old-releases.ubuntu.com/ubuntu/dists/eoan-updates/main/dist-upgrader-all/current/eoan.tar.gz
Now pull this over to a directory on your server
wget http://old-releases.ubuntu.com/ubuntu/dists/eoan-updates/main/dist-upgrader-all/current/eoan.tar.gz
mkdir eoan_upgrade
tar -xvzf  eoan.tar.gz -C eoan_upgrade
cd eoan_upgrade
Run the upgrade script
sudo ./eoan
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
Stalinko
  • 263
13
Faced the same problem after end of life. The process to upgrade to 20.04 was first to upgrade to 19.10. Following is how I upgraded 19.04 to 19.10
  1. Open /etc/apt/sources.list
  2. Delete everything and replace it with the following: (you might want to keep a backup just in case)
deb http://old-releases.ubuntu.com/ubuntu eoan main
deb http://old-releases.ubuntu.com/ubuntu eoan-updates main
deb http://old-releases.ubuntu.com/ubuntu eoan-security main
  1. Finally, just run these commands one by one:
sudo apt update
sudo apt upgrade
That's basically it. Ubuntu should now be upgraded to 19.10 (Eoan)
Now it is an easy task to upgrade from Eoan to Focal (20.04)
As suggested by @xiaojueguan, run the following command to upgrade from Eoan to Focal:
do-release-upgrade
Note: After you update to Eoan, you may want to update your sources.list file. You can find it here:
Eoan (Ubuntu 19.10): https://gist.github.com/malikalichsan/860b8134a74c65a394efe09711d0b95f
Focal (Ubuntu 20.04): https://gist.github.com/ishad0w/788555191c7037e249a439542c53e170
Summary:
Do an intermediary upgrade disco=>eoan=>focal
Alternate upgrade
  1. I tried part of @misteeque solution and changed all the /etc/apt/sources.list to old-release. So, can't tell if this had an impact on the steps below. I also did the http://security... ones. Comment if 0. is not needed.
  2. sudo wget http://old-releases.ubuntu.com/ubuntu/dists/eoan-updates/main/dist-upgrader-all/current/eoan.tar.gz
  3. sudo mkdir eoan_upgrade && sudo mkdir eoan_upgrade
  4. cd eoan_upgrade
  5. sudo ./eoan
  6. sudo do-release-upgrade and do 5. again to get to focal
lsb_release -a is helpful to check pre and post upgrades.
Hillsie
  • 131
