Since I recently installed Ubuntu 20.04 on my laptop, a few days after a reboot the graphics starts to freeze for about 1.5 seconds every 5 seconds. It goes away immediately after a reboot, but I have not yet noticed a pattern for what causes it to return a few days later.
I would be grateful if someone could point me at ways to get closer to diagnosing the problem, even if they don't have a solution.
It seems to be purely graphics-related (and not CPU, network or swap-related), because it even affects a lone system monitor process as can be seen in this screencast of the system monitor plots sticking every 5 seconds, where you can also see how idle the CPU and network are and how much free memory and swap there is (the CPU hike is the recording process for the 30s duration of the screencast).
It even affects a gnome-terminal session scrolling output from sudo find /, as shown in this screencast (it normally scrolls smoothly).
However, it does not affect the mouse pointer, which continues to respond normally while the rest of the graphics is stuck. And audio continues uninterrupted.
It makes interactive video or video playback (whether from disk or from network) unusable, as this screencast shows. Note that the graphics jumps rather than fast-forwards once it unsticks.
Next time it occurs, I will report any clues found from dmesg.
System details: Lenovo Yoga Pro 3 laptop, Mesa IntelĀ® HD Graphics 5300 (Intel BDW GT2 chipset) Ubuntu 20.04 over Linux 5.4.0-40-generic amd64 architecture. Recent fresh install.
$ sudo lshw -c display
*-display
description: VGA compatible controller
product: HD Graphics 5300
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:64 memory:c0000000-c0ffffff memory:b0000000-bfffffff ioport:3000(size=64) memory:c0000-dffff
Top processes in CPU usage with no user-processes running except gnome-system-monitor:
~40% gnome-shell
~20% Xorg
~ 4% gnome-system-monitor
<0.3% <each other process>
Without system monitor (just top in a lone gnome-terminal):
~12% gnome-shell
~ 5% Xorg
I've found several other similar reports. For instance this one is with Ubuntu 18.04 and Intel HD graphics (gives few details and no solution) or this with 16.04 (but dual gpu) or this with 20.04 (but nVidia and not solved by reboot) or this with Radeon (but mouse froze - and solved at BIOS level by setting graphics to Discrete, which I don't have).
Numerous posts from 2015 era such as this are resolved by adding an acpi_rev_override=1 argument to splash in /etc/default/grub. However, unlike my case, the mouse pointer freezes and they all relate to nVidia.
