So I keep getting this error when doing an upgrade, but I cant find a solution on how to resolve it. Im on Ubuntu 20.04
sudo apt dist-upgrade
Reading package lists...
Done Building dependency tree
Reading state information...
Done Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
ERROR couldn't connect to zsys daemon: connection error: desc = "transport: Error while dialing dial unix /run/zsysd.sock: connect: no such file or directory"
Setting up zsys (0.4.6) ... dpkg: error processing package zsys (--configure):  installed zsys package
post-installation script subprocess returned error exit  status 1
Errors were encountered while processing:  zsys ERROR couldn't connect to zsys daemon: connection error: desc = "transport: Error while dialing dial unix /run/zsysd.sock: connect: no such file or directory"
What can I do to solve the error?
Serafim
  • 515
Keltari
  • 201
There is a bug in zsys here: https://bugs.launchpad.net/ubuntu/+source/zsys/+bug/1886214.
One solution is to do this:
  1. Enable proposed branch in your repository and update.
$ echo "deb http://archive.ubuntu.com/ubuntu/ $(lsb_release -cs)-proposed main" | sudo tee /etc/apt/sources.list.d/proposed-repositories.list
$ sudo apt update
  1. Install zsys v0.4.7 (as of today, 10 Aug 2020) by:
$ sudo apt -t $(lsb_release -cs)-proposed install zsys
  1. Remove the proposed branch if you don't want it to stay:
$ sudo rm /etc/apt/sources.list.d/proposed-repositories.list
$ sudo apt update
Majal
  • 8,249
