I often use
du --max-depth=n -h | sort --human-numeric-sort
Now I want to use tree, in a similar manner. I found here a partial answer
tree -sh --sort=size --du
where --du makes tree reporting the cumulative size for each directory (as du). This reports each file as well. If I want to report only directories, I should add -d to tree. But -d seems to do two things:
  1. Remove files from the report.
  2. Remove the size of files from the cumulative total computed for each dir.
Of course, I want only 1, not 2 (as du does). So
tree -sh --sort=size --du -d
would always report "small" sizes, without considering file sizes.
Can tree overcome this? Is there any alternative?
This is definetely a shortcoming of tree. It only summarize sizes of "what it sees". If you ignore files with -d or -I or if you limit the depth, tree will report a "wrong" dir size.
If you don't need to restrict levels, this works fine:
tree --du -shaC | sed -n '/\[01;34m/p'
Wiht 01;34 being the color value for directories from LS_COLORS env variable (...di=01;34...).
If you want to restrict levels though, the deepest level will still report wrong dir size with this method.
Consider using a more advanced tool such as ncdu.
See also this very similar question at U&L SE.
pLumo
  • 27,991
