I have installed pulseaudio-equalizer in Ubuntu 20.04 LTS.
Right after the installation, I got the error There was an error connecting to pulseadio, please make sure you have the pulseaudio dbus module loaded, exiting..., which is solved in this related question How do I start pulseaudio-equalizer?
However, implementing the above solution, I now get the error Command 'qpaeg' not found, did you mean ...
Paul
  • 430
Daniel
  • 177
Note: I use debian/openbox to prefer open source
cp /etc/pulse/default.pa ~/.config/pulse/
insert following lines into ~/.config/pulse/
# solve "error connecting to pulseaudio..." after invoking qpaeq from package pulseaudio-equalizer
load-module module-equalizer-sink
load-module module-dbus-protocol
restart pulse audio via
$ pulseaudio --kill
$ pulseaudio --start
Then I used pavucontrol and chose "FFT based equalizer on ..." in the Playback tab as the desired output for the desired program playing music. I would prefer to use pactl to perform the task so that I can create an equalizer on/off keystroke.
Pulseaudio should save the chosen state for each program in ~/.config/pulse/.
Cooloutac on wiki gitlab says that if you have static and crackling when using the qpaeq, then you must append for modify existing udev module line to read
load-module module-udev-detect tsched=0
Don't forget to restart pulseaudio with every change to default.pa.
Paul
  • 430
