I updated today, then rebooted. The outcome is that the volume group cannot be found and it drops out to BusyBox.
I tried:
  • "vgchange -ay" out from the busybox -> did nothing.
  • Booting with an older kernel -> same outcome.
  • Then I started from a live CD.
I found this webpage: Recovering from an unbootable Ubuntu encrypted LVM root partition, but my /etc/crypttab is empty.
Here you see how the filesystem is structured:
lsblk --fs
The two SSDs sda and sdb create on a 3ware controller the raid 1 array sdc. A softraid 1 is then initiated on the 2x 8TB HDDs (which are recognized by the BIOS, but cannot be accessed (unless I knew how) from the live CD even the crypt on the SSDs is opened up.
So I guess ... first things first... that I need to fix the volume group to be found during boot.
If I first unlock the crypt & run sudo vgchange -ay on the live CD, then it looks promising:
2 logical volume(s) in volume group "hal9999-vg" now active
However after rebooting still the Volume Group cannot be found.
I read that this problem occurs in relation to LVM and initramfs, but I don't want to mess around randomly with my filesystems in order to avoid getting in bigger trouble.
In the meantime I tried this answer. It flooded my crypttab, but update-initramfs -u -k all failed:
update-initramfs: Generating /boot/initrd.img-5.4.0-40-generic
cryptsetup: WARNING: target 'luks-524c1ad6-fabe-4f32-9bb0-c8db1286b262' not
    found in /etc/crypttab
W: /sbin/fsck.crypto_LUKS doesn't exist, can't install to initramfs
After all this is the current status:
Output of lsblk -fs:
NAME                 FSTYPE            LABEL       UUID                                   MOUNTPOINT
loop0                squashfs                                                             /rofs
sda                  linux_raid_member hal9999:0   853e3329-6076-8398-e0d8-19149c7d0d64
sdb                  linux_raid_member hal9999:0   853e3329-6076-8398-e0d8-19149c7d0d64
sdc1                 vfat                          94B1-AF12
└─sdc
sdc2                 ext4                          bbb39977-bf4a-4d8b-b524-7c29a85471d0   /mnt/boot
└─sdc
sdd1                 vfat              XUBUNTU 18_ 849C-7AF8                              /cdrom
└─sdd
hal9999--vg-root     ext4                          17c06541-b952-41a2-b28d-b37e49771625   /mnt
└─luks-524c1ad6-fabe-4f32-9bb0-c8db1286b262
                     LVM2_member                   JK4UPj-KdoV-yFe5-XBZW-cHFP-JCbV-JsLjPq
  └─sdc3             crypto_LUKS                   524c1ad6-fabe-4f32-9bb0-c8db1286b262
    └─sdc
hal9999--vg-swap_1   swap                          cd5a6a21-dea3-46a9-a524-e43de19c0587
    └─sdc
/etc/crypttab:
sdc3_crypt UUID=524c1ad6-fabe-4f32-9bb0-c8db1286b262 none luks,discard
data /dev/md0 /root/drive_key luks
/etc/cryptsetup-initramfs/conf-hook:
# Configuration file for the cryptroot initramfs hook.
KEYFILE_PATTERN: ...
The value of this variable is interpreted as a shell pattern.
Matching key files from the crypttab(5) are included in the initramfs
image. The associated devices can then be unlocked without manual
intervention. (For instance if /etc/crypttab lists two key files
/etc/keys/{root,swap}.key, you can set KEYFILE_PATTERN="/etc/keys/*.key"
to add them to the initrd.)
If KEYFILE_PATTERN if null or unset (default) then no key file is
copied to the initramfs image.
Note that the glob(7) is not expanded for crypttab(5) entries with a
'keyscript=' option. In that case, the field is not treated as a file
name but given as argument to the keyscript.
WARNING: If the initramfs image is to include private key material,
you'll want to create it with a restrictive umask in order to keep
non-privileged users at bay. For instance, set UMASK=0077 in
/etc/initramfs-tools/initramfs.conf
#KEYFILE_PATTERN= CRYPTSETUP=Y
/etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
UUID=524c1ad6-fabe-4f32-9bb0-c8db1286b262 /               ext4    errors=remount-ro 0       1
#/dev/mapper/hal9999--vg-root /               ext4    errors=remount-ro 0       1
# /boot was on /dev/sdc2 during installation
UUID=bbb39977-bf4a-4d8b-b524-7c29a85471d0 /boot           ext4    defaults        0       2
# /boot/efi was on /dev/sdc1 during installation
UUID=94B1-AF12  /boot/efi       vfat    umask=0077      0       1
/dev/mapper/hal9999--vg-swap_1 none            swap    sw              0       0
#/dev/md0 /mnt/md0 ext4 defaults,nofail,discard 0 0
/dev/mapper/data /mnt/data ext4 defaults 0 2
It looks like the diagnosis "Ubuntu accidentally removed lvm and cryptsetup at the last update" may be the case.
I ran these commands:
root@xubuntu:/home/xubuntu# mount /dev/mapper/sdc2 /mnt/boot
mount: /mnt/boot: special device /dev/mapper/sdc2 does not exist.
root@xubuntu:/home/xubuntu# mount /dev/sdc2 /mnt/boot
root@xubuntu:/home/xubuntu# mount -t proc proc /mnt/proc
root@xubuntu:/home/xubuntu# mount -o bind /dev /mnt/dev
root@xubuntu:/home/xubuntu# mount -o bind /sys /mnt/sys
root@xubuntu:/home/xubuntu# chroot /mnt
...and changed /etc/fstab to:
#UUID=524c1ad6-fabe-4f32-9bb0-c8db1286b262 /               ext4    errors=remount-ro 0       1
Now I'm getting this error on update-initramfs -c -k all:
update-initramfs: Generating /boot/initrd.img-5.4.0-39-generic
New output:
xubuntu@xubuntu:~$ lsblk --fs
sdc
├─sdc1               vfat                          94B1-AF12
├─sdc2               ext4                          bbb39977-bf4a-4d8b-b524-7c29a85471d0   /mnt/boot
  └─sdc3_crypt       LVM2_member                   JK4UPj-KdoV-yFe5-XBZW-cHFP-JCbV-JsLjPq
    ├─hal9999--vg-root
    │                ext4                          17c06541-b952-41a2-b28d-b37e49771625   /mnt
    └─hal9999--vg-swap_1
sdd
└─sdd1               vfat              XUBUNTU 18_ 849C-7AF8                              /cdrom
New error: results of update-initramfs -c -k all:
update-initramfs: Generating /boot/initrd.img-5.3.0-59-generic
cryptsetup: ERROR: Couldn't resolve device
    UUID=luks-524c1ad6-fabe-4f32-9bb0-c8db1286b262
karel
  • 122,292
  • 133
  • 301
  • 332
jak83
  • 15
  1. Run:
    dmsetup -u sdc3_crypt <UUID of crypt partition>
  2. Change fstab so /dev/mapper/>rootpartition (see below) is named.
  3. Remove luks prefix in crypttab before UUID (see below).
New working fstab:
# crypt /dev/sdc3  none luks,initramfs
New working crypttab:
# sdc3_crypt UUID=524c1ad6-fabe-4f32-9bb0-c8db1286b262 none luks,discard
# luks-524c1ad6-fabe-4f32-9bb0-c8db1286b262 UUID=luks-524c1ad6-fabe-4f32-9bb0-c8db1286b262 none luk>
# UUID=luks-524c1ad6-fabe-4f32-9bb0-c8db1286b262 none luks,discard
#sdc3_crypt UUID=JK4UPj-KdoV-yFe5-XBZW-cHFP-JCbV-JsLjPq none luks,discard
Now update-initramfs -c -k all ran through without any errors, so reboot went through and the filesystem was found.
karel
  • 122,292
  • 133
  • 301
  • 332
