10
I am using ubuntu 20.04 LTS. I don't know how I did this, but I tried to customize my dock settings using dash to dock extension. But then I realized that the space between 2 icons on the dock is too much and I don't like it. I need the default values. There isn't any option in the dconF-editor also. As you can see in these images, there is a huge space between my dock icons. Is there any method to correct this?
This is how my dock appears
This is the default dock
Nadeesha
  • 101
You can do this following these two steps described below -
  1. Change dashToDock extension setting -
    a. open dconf editor
    b. go to org/gnome/shell/extensions/dash-to-dock/
    c. turn on custom-theme-shrink
  2. Now you have to change theme css file -
    a. now go to /usr/share/themes/Yaru-dark/gnome-shell/
    (I'm assuming that you are using Yaru-dark shell theme)
    b. open gnome-shell.css file in a text editor
    c. search these lines of code -
    #dashtodockContainer.shrink .dash-item-container > StButton, #dashtodockContainer.dashtodock .dash-item-container > StButton {
    padding: 2px 4px !important; }
    d. change padding to -
    padding: 0px 0px !important;
Now restart your gnome-shell by pressing Alt+f2 and then running r command
If you're using a theme go to /home/{user}/.themes/{theme name}/gnome-shell/gnome-shell.css
or for system theme go to /usr/share/gnome-shell/theme
find this line of code
  #dashtodockContainer .show-apps .overview-icon {
  padding: 4px;
  background-size: contain;
and change padding to whichever value suits you. Log out and log back in.
if you're using dash to dock extension put this at the bottem of gnome-shell/extensions/dash-to-dock/stylesheet.css
#dashtodockContainer .overview-icon {
padding-top:2px;
padding-bottom:2px;
padding-right: 1px;
padding-left: 1px;
#dashtodockContainer.icon { padding-top:1px; padding-bottom:1px; padding-right: 1px; padding-left: 1px; border-radius: 0px;/for square border / }
then reload using alt+f2 and r
source
Also change the outermost border using
padding: 1px 2px; /* padding between icon borders */
