I'm using an HP laptop with Windows/Ubuntu 18.04, but after a reinstallation of Ubuntu, I can't boot into Windows. Advanced options for Ubuntu and system settings, but I can't find the option for accessing Windows.
I don't really know what the problem is. I tried a lot of suggestions here, but none worked.
  1. I tried the accepted answer in this question (Unable to boot into Windows after installing Ubuntu, how to fix?), after creating a file and rebooting. I could see an option called Windows-UEFI. But if I try to click on that and proceed I get the error,
    error : no such device : /EFI/Microsoft/Boot/bootmgfw.efi.
    error : file /EFI/Microsoft/Boot/bootmgfw.efi' not found.
  2. Then I tried running the Boot Info Script (http://bootinfoscript.sourceforge.net/). The output is uploaded here: https://file.io/vuch51vB.
============================= Boot Info Summary: ===============================
=> No boot loader is installed in the MBR of /dev/sda.
sda1: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  No errors found in the Boot Parameter Block.
Operating System:
Boot files:        /efi/BOOT/fbx64.efi /efi/ubuntu/grubx64.efi
                   /efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
sda2: __________________________________________________________________________
File system:
Boot sector type:  -
Boot sector info:
Mounting failed:   mount: /tmp/BootInfo-QDw4MMPm/sda2: unknown filesystem type ''.
sda3: __________________________________________________________________________
File system:       ntfs
Boot sector type:  Windows Vista/7: NTFS
Operating System:
Boot files:        /Windows/System32/winload.exe
sda4: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:
sda5: __________________________________________________________________________
File system:       ntfs
Operating System:
Boot files:        /bootmgr /Boot/BCD
sda6: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 18.04.4 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab
sda8: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:
Boot files:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________ Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 1 1,953,525,167 1,953,525,167 ee GPT
GUID Partition Table detected.
Partition Start Sector End Sector # of Sectors System /dev/sda1 2,048 534,527 532,480 EFI System partition /dev/sda2 534,528 567,295 32,768 Microsoft Reserved Partition (Windows) /dev/sda3 567,296 371,412,991 370,845,696 Data partition (Windows/Linux) /dev/sda4 1,917,038,592 1,919,045,631 2,007,040 Windows Recovery Environment (Windows) /dev/sda5 1,919,045,632 1,953,511,423 34,465,792 Data partition (Windows/Linux) /dev/sda6 371,412,992 694,374,399 322,961,408 Data partition (Linux) /dev/sda8 694,374,400 1,917,038,591 1,222,664,192 Data partition (Linux)
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/loop1 squashfs
/dev/loop10 squashfs
/dev/loop11 squashfs
/dev/loop12 squashfs
/dev/loop13 squashfs
/dev/loop14 squashfs
/dev/loop15 squashfs
/dev/loop16 squashfs
/dev/loop17 squashfs
/dev/loop18 squashfs
/dev/loop19 squashfs
/dev/loop2 squashfs
/dev/loop20 squashfs
/dev/loop21 squashfs
/dev/loop22 squashfs
/dev/loop23 squashfs
/dev/loop24 squashfs
/dev/loop25 squashfs
/dev/loop3 squashfs
/dev/loop4 squashfs
/dev/loop5 squashfs
/dev/loop6 squashfs
/dev/loop7 squashfs
/dev/loop8 squashfs
/dev/loop9 squashfs
/dev/sda1 E52D-D92B vfat
/dev/sda2
/dev/sda3 4410959410958E14 ntfs Windows /dev/sda4 6C6CDA8F6CDA5384 ntfs Windows RE tools /dev/sda5 009052CF9052CAB4 ntfs RECOVERY /dev/sda6 921eabcd-626b-4ecc-bd47-40ea213357f1 ext4
/dev/sda8 4f953876-2a36-48ef-9ee9-47206f509d05 ext4
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda1 /boot/efi vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) /dev/sda6 / ext4 (rw,relatime,errors=remount-ro) /dev/sda8 /home ext4 (rw,noatime)
=========================== sda6/boot/grub/grub.cfg: ===========================
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then set have_grubenv=true load_env fi if [ "${next_entry}" ] ; then set default="${next_entry}" set next_entry= save_env next_entry set boot_once=true else set default="0" fi
if [ x"${feature_menuentry_id}" = xy ]; then menuentry_id_option="--id" else menuentry_id_option="" fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then set saved_entry="${prev_saved_entry}" save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=true fi
function savedefault { if [ -z "${boot_once}" ]; then saved_entry="${chosen}" save_env saved_entry fi } function recordfail { set recordfail=1 if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi } function load_video { if [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod efi_uga insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi }
if [ x$feature_default_font_path = xy ] ; then font=unicode else insmod part_gpt insmod ext2 set root='hd0,gpt6' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6 921eabcd-626b-4ecc-bd47-40ea213357f1 else search --no-floppy --fs-uuid --set=root 921eabcd-626b-4ecc-bd47-40ea213357f1 fi font="/usr/share/grub/unicode.pf2" fi
if loadfont $font ; then set gfxmode=auto load_video insmod gfxterm set locale_dir=$prefix/locale set lang=en_US insmod gettext fi terminal_output gfxterm if [ "${recordfail}" = 1 ] ; then set timeout=30 else if [ x$feature_timeout_style = xy ] ; then set timeout_style=hidden set timeout=0
Fallback hidden-timeout code in case the timeout_style feature is
unavailable.
elif sleep --interruptible 0 ; then set timeout=0 fi fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black set menu_color_highlight=black/light-gray if background_color 44,0,30,0; then clear fi
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
function gfxmode { set gfxpayload="${1}" if [ "${1}" = "keep" ]; then set vt_handoff=vt.handoff=1 else set vt_handoff= fi } if [ "${recordfail}" != 1 ]; then if [ -e ${prefix}/gfxblacklist.txt ]; then if hwmatch ${prefix}/gfxblacklist.txt 3; then if [ ${match} = 0 ]; then set linux_gfx_mode=keep else set linux_gfx_mode=text fi else set linux_gfx_mode=text fi else set linux_gfx_mode=keep fi else set linux_gfx_mode=text fi export linux_gfx_mode menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-921eabcd-626b-4ecc-bd47-40ea213357f1' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd0,gpt6' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6 921eabcd-626b-4ecc-bd47-40ea213357f1 else search --no-floppy --fs-uuid --set=root 921eabcd-626b-4ecc-bd47-40ea213357f1 fi linux /boot/vmlinuz-5.3.0-59-generic root=UUID=921eabcd-626b-4ecc-bd47-40ea213357f1 ro quiet splash $vt_handoff initrd /boot/initrd.img-5.3.0-59-generic } submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-921eabcd-626b-4ecc-bd47-40ea213357f1' { menuentry 'Ubuntu, with Linux 5.3.0-59-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.0-59-generic-advanced-921eabcd-626b-4ecc-bd47-40ea213357f1' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd0,gpt6' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6 921eabcd-626b-4ecc-bd47-40ea213357f1 else search --no-floppy --fs-uuid --set=root 921eabcd-626b-4ecc-bd47-40ea213357f1 fi echo 'Loading Linux 5.3.0-59-generic ...' linux /boot/vmlinuz-5.3.0-59-generic root=UUID=921eabcd-626b-4ecc-bd47-40ea213357f1 ro quiet splash $vt_handoff echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-5.3.0-59-generic } menuentry 'Ubuntu, with Linux 5.3.0-59-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.0-59-generic-recovery-921eabcd-626b-4ecc-bd47-40ea213357f1' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd0,gpt6' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6 921eabcd-626b-4ecc-bd47-40ea213357f1 else search --no-floppy --fs-uuid --set=root 921eabcd-626b-4ecc-bd47-40ea213357f1 fi echo 'Loading Linux 5.3.0-59-generic ...' linux /boot/vmlinuz-5.3.0-59-generic root=UUID=921eabcd-626b-4ecc-bd47-40ea213357f1 ro recovery nomodeset echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-5.3.0-59-generic } menuentry 'Ubuntu, with Linux 5.3.0-53-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.0-53-generic-advanced-921eabcd-626b-4ecc-bd47-40ea213357f1' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd0,gpt6' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6 921eabcd-626b-4ecc-bd47-40ea213357f1 else search --no-floppy --fs-uuid --set=root 921eabcd-626b-4ecc-bd47-40ea213357f1 fi echo 'Loading Linux 5.3.0-53-generic ...' linux /boot/vmlinuz-5.3.0-53-generic root=UUID=921eabcd-626b-4ecc-bd47-40ea213357f1 ro quiet splash $vt_handoff echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-5.3.0-53-generic } menuentry 'Ubuntu, with Linux 5.3.0-53-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.3.0-53-generic-recovery-921eabcd-626b-4ecc-bd47-40ea213357f1' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 set root='hd0,gpt6' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt6 --hint-efi=hd0,gpt6 --hint-baremetal=ahci0,gpt6 921eabcd-626b-4ecc-bd47-40ea213357f1 else search --no-floppy --fs-uuid --set=root 921eabcd-626b-4ecc-bd47-40ea213357f1 fi echo 'Loading Linux 5.3.0-53-generic ...' linux /boot/vmlinuz-5.3.0-53-generic root=UUID=921eabcd-626b-4ecc-bd47-40ea213357f1 ro recovery nomodeset echo 'Loading initial ramdisk ...' initrd /boot/initrd.img-5.3.0-53-generic } }
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/20_memtest86+
END /etc/grub.d/20_memtest86+
BEGIN /etc/grub.d/30_os-prober
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
menuentry 'System setup' $menuentry_id_option 'uefi-firmware' { fwsetup }
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the 'exec tail' line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f ${config_directory}/custom.cfg ]; then source ${config_directory}/custom.cfg elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then source $prefix/custom.cfg; fi
END /etc/grub.d/41_custom
=============================== sda6/etc/fstab: ================================
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda6 during installation
UUID=921eabcd-626b-4ecc-bd47-40ea213357f1 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
UUID=E52D-D92B /boot/efi vfat umask=0077 0 1 /swapfile none swap sw 0 0
/home is on /dev/sda8, edited after install
UUID=4f953876-2a36-48ef-9ee9-47206f509d05 /home ext4 noatime 0 2
=================== sda6: Location of files loaded by Grub: ====================
       GiB - GB             File                                 Fragment(s)
=============================== StdErr Messages: ===============================
cat: /tmp/BootInfo-QDw4MMPm/Tmp_Log: No such file or directory
  1. I tried editing the grub-file as mentioned here (Unable to boot into Windows after Ubuntu 14.04.3 installation)
It did not work either.
At this point, I don't know what exactly my problem is. also I'm scared of messing up the whole system if I try new solutions without knowing what I'm doing. Can anyone help me to find out the problem?
karel
  • 122,292
  • 133
  • 301
  • 332
brownser
  • 148
Assuming a UEFI install of both Window and Ubuntu
  1. Check efibootmgr -v
This will verbosely produce something like this:
efibootmgr -v
BootCurrent: 0003
Timeout: 60 seconds
BootOrder: 0003,0000,001D,000B,000C,000E,000D,001B,001C,001E
Boot0000* Windows Boot Manager  HD(2,GPT,63c4ca60-c3b9-45a4-979a-f25f25c3d28e,0x1f4800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0001  Startup Interrupt Menu    FvFile(f46ee6f4-4785-43a3-923d-7f786c3c8479)
Boot0002  Rescue and Recovery   FvFile(665d3f60-ad3e-4cad-8e26-db46eee9f1b5)
Boot0003* ubuntu    HD(2,GPT,63c4ca60-c3b9-45a4-979a-f25f25c3d28e,0x1f4800,0x82000)/File(\EFI\ubuntu\shimx64.efi)
Boot0005  Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot0006  Boot Menu FvFile(126a762d-5758-4fca-8531-201a7f57f850)
Boot0007  Diagnostic Splash Screen  FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0008  Lenovo Diagnostics    FvFile(3f7e615b-0d45-4f80-88dc-26b234958560)
Boot000B* USB CD    VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot000C* USB FDD   VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot000D* ATAPI CD1 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a35404)
Boot000E* ATA HDD0  VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f600)
Boot001B* ATA HDD1  VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f602)
Boot001C* ATA HDD2  VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f603)
Boot001D* USB HDD   VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,33e821aaaf33bc4789bd419f88c50803)
Boot001E* PCI LAN   VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
My complicated setup has the advantage of booting from several entries, but as I can see NO evidence of bootmgfw.efi (I suggest you try find / -name '*.efi') , I presume you have thoroughly checked all your file systems for errors.
Failing success, using information from your efibootmgr`try in my case as an example:
efibootmgr -n 000E
In the above this will produce a one time boot attempt by looking for the entry 000Ein the list. Which yields BOOT000E ATA HDD0 in my case, in yours you need to find the entries corresponding to sda3-6[given they contain Windows components], and try each.
These entries are added by UEFI (in BIOS) boot selection order, and are not normally removed, but re-ordered.
EDIT 1: sda1 Contains what looks like a normal EFI boot structure but sda6 contains Both /boot and /BCD (the windows registry) Use the above find , combined with your efibootmgr output, which should indicate where your Windows boot structure/disk is found or can be rebuilt from.
Typing efibootmgrwithout '-v'_ yields a simpler , less informative structure:
efibootmgr
BootCurrent: 0003
Timeout: 0 seconds
Boot0003* ubuntu
Boot0005  Setup
Boot0006  Boot Menu
Boot000B* USB CD
Boot000C* USB FDD
Boot000D* ATAPI CD1
Boot000E* ATA HDD0
Boot001B* ATA HDD1
Boot001C* ATA HDD2
Boot001D* USB HDD
Boot001E* PCI LAN
EDIT 2:
If the file systems sda1-7 are not mounted in order to run the above find.. command, successively try mkdir /tmp/sda1, mount /dev/sda1 /tmp/sda1 and find /tmp/sda1 -name '*.efi', replacing sda1 for each partition.
As the previous threads have indicated,the goal is to find the correct .efi
EDIT 3 Best solution:
After reading the first links you provided, I ran the bootinfoscripton my m/c, guess what? It doesn't look for the bootmgfw.efiat all!
The best suggestion provided by @Jordan Uggla in unable-to-boot-into-windows-after-installing-ubuntu-how-to-fix) provides the solution:
Your /dev/sda1 partition must contain the Windows bootmgfw.efi as it is the defacto EFI partition, so based on @Jordan Uggla 's work , I edited it to:
Create a file, /boot/grub/custom.cfg (by running sudo -H gedit /boot/grub/custom.cfg) with these contents:
#This entry should work for any version of Windows installed for UEFI booting
menuentry 'Windows Boot Manager (on /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-efi-E52D-D92B' { insmod part_gpt insmod fat set root='hd0,gpt1' if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt1 --hint- efi=hd0,gpt1 --hint-baremetal=ahci0,gpt1 E52D-D92B else search --no-floppy --fs-uuid --set=root E52D-D92B fi chainloader /EFI/Microsoft/Boot/bootmgfw.efi }
(Copy and paste the above into the Gedit window that comes up, then save and quit Gedit)
Reboot and you should see an entry titled Windows Boot Manager (on /dev/sda1) and if you select it then Windows should boot, do look for the bootmgfw.efiin /boot , try ls -R /boot|more I'm sure it's in there!
