22
I'm an inexperienced Linux user but have been fiddling around for a few months. I need to use python 3.5-3.7 for a project, but cannot install python3.7 from a tarball like mentioned here: Install Python 3.7 packages in Ubuntu 20.04
I've provided the output to the terminal here:(sorry it's so long i don't know what's relevant)
See error log
ERROR: Command errored out with exit status 1:
   command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-_od32i_x/setup.py'"'"'; __file__='"'"'/tmp/pip-req-build-_od32i_x/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-spo6ltjl
       cwd: /tmp/pip-req-build-_od32i_x/
  Complete output (230 lines):
  running bdist_wheel
  running build
  running build_ext
  INFO: Can't locate Tcl/Tk libs and/or headers
 building '_ctypes_test' extension
 creating build/temp.linux-x86_64-3.8/_ctypes
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _ctypes/_ctypes_test.c -o build/temp.linux-x86_64-3.8/_ctypes/_ctypes_test.o
 x86_64-linux-gnu-gcc: error: _ctypes/_ctypes_test.c: No such file or directory
 x86_64-linux-gnu-gcc: fatal error: no input files
 compilation terminated.
 building '_contextvars' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _contextvarsmodule.c -o build/temp.linux-x86_64-3.8/_contextvarsmodule.o
 x86_64-linux-gnu-gcc: error: _contextvarsmodule.c: No such file or directory
 building '_json' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _json.c -o build/temp.linux-x86_64-3.8/_json.o
 x86_64-linux-gnu-gcc: error: _json.c: No such file or directory
 building '_testcapi' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _testcapimodule.c -o build/temp.linux-x86_64-3.8/_testcapimodule.o
 x86_64-linux-gnu-gcc: error: _testcapimodule.c: No such file or directory
 building '_testbuffer' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _testbuffer.c -o build/temp.linux-x86_64-3.8/_testbuffer.o
 x86_64-linux-gnu-gcc: error: _testbuffer.c: No such file or directory
 building '_testimportmultiple' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _testimportmultiple.c -o build/temp.linux-x86_64-3.8/_testimportmultiple.o
 x86_64-linux-gnu-gcc: error: _testimportmultiple.c: No such file or directory
 building '_testmultiphase' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _testmultiphase.c -o build/temp.linux-x86_64-3.8/_testmultiphase.o
 x86_64-linux-gnu-gcc: error: _testmultiphase.c: No such file or directory
 building '_lsprof' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _lsprof.c -o build/temp.linux-x86_64-3.8/_lsprof.o
 x86_64-linux-gnu-gcc: error: _lsprof.c: No such file or directory
 building '_opcode' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _opcode.c -o build/temp.linux-x86_64-3.8/_opcode.o
 x86_64-linux-gnu-gcc: error: _opcode.c: No such file or directory
 building '_asyncio' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _asynciomodule.c -o build/temp.linux-x86_64-3.8/_asynciomodule.o
 x86_64-linux-gnu-gcc: error: _asynciomodule.c: No such file or directory
 building '_queue' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _queuemodule.c -o build/temp.linux-x86_64-3.8/_queuemodule.o
 x86_64-linux-gnu-gcc: error: _queuemodule.c: No such file or directory
 building 'parser' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c parsermodule.c -o build/temp.linux-x86_64-3.8/parsermodule.o
 x86_64-linux-gnu-gcc: error: parsermodule.c: No such file or directory
 building 'mmap' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c mmapmodule.c -o build/temp.linux-x86_64-3.8/mmapmodule.o
 x86_64-linux-gnu-gcc: error: mmapmodule.c: No such file or directory
 building '_xxtestfuzz' extension
 creating build/temp.linux-x86_64-3.8/_xxtestfuzz
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _xxtestfuzz/_xxtestfuzz.c -o build/temp.linux-x86_64-3.8/_xxtestfuzz/_xxtestfuzz.o
 x86_64-linux-gnu-gcc: error: _xxtestfuzz/_xxtestfuzz.c: No such file or directory
 building 'audioop' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c audioop.c -o build/temp.linux-x86_64-3.8/audioop.o
 x86_64-linux-gnu-gcc: error: audioop.c: No such file or directory
 building '_crypt' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _cryptmodule.c -o build/temp.linux-x86_64-3.8/_cryptmodule.o
 x86_64-linux-gnu-gcc: error: _cryptmodule.c: No such file or directory
 building '_ssl' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _ssl.c -o build/temp.linux-x86_64-3.8/_ssl.o
 x86_64-linux-gnu-gcc: error: _ssl.c: No such file or directory
 building '_hashlib' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _hashopenssl.c -o build/temp.linux-x86_64-3.8/_hashopenssl.o
 x86_64-linux-gnu-gcc: error: _hashopenssl.c: No such file or directory
 building 'termios' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c termios.c -o build/temp.linux-x86_64-3.8/termios.o
 x86_64-linux-gnu-gcc: error: termios.c: No such file or directory
 building 'resource' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c resource.c -o build/temp.linux-x86_64-3.8/resource.o
 x86_64-linux-gnu-gcc: error: resource.c: No such file or directory
 building 'nis' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c nismodule.c -o build/temp.linux-x86_64-3.8/nismodule.o
 x86_64-linux-gnu-gcc: error: nismodule.c: No such file or directory
 building '_curses' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DHAVE_NCURSESW=1 -I/usr/include/ncursesw -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _cursesmodule.c -o build/temp.linux-x86_64-3.8/_cursesmodule.o
 x86_64-linux-gnu-gcc: error: _cursesmodule.c: No such file or directory
 building '_curses_panel' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DHAVE_NCURSESW=1 -I/usr/include/ncursesw -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _curses_panel.c -o build/temp.linux-x86_64-3.8/_curses_panel.o
 x86_64-linux-gnu-gcc: error: _curses_panel.c: No such file or directory
 building '_multibytecodec' extension
 creating build/temp.linux-x86_64-3.8/cjkcodecs
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/multibytecodec.c -o build/temp.linux-x86_64-3.8/cjkcodecs/multibytecodec.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/multibytecodec.c: No such file or directory
 building '_codecs_kr' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/_codecs_kr.c -o build/temp.linux-x86_64-3.8/cjkcodecs/_codecs_kr.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/_codecs_kr.c: No such file or directory
 building '_codecs_jp' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/_codecs_jp.c -o build/temp.linux-x86_64-3.8/cjkcodecs/_codecs_jp.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/_codecs_jp.c: No such file or directory
 building '_codecs_cn' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/_codecs_cn.c -o build/temp.linux-x86_64-3.8/cjkcodecs/_codecs_cn.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/_codecs_cn.c: No such file or directory
 building '_codecs_tw' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/_codecs_tw.c -o build/temp.linux-x86_64-3.8/cjkcodecs/_codecs_tw.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/_codecs_tw.c: No such file or directory
 building '_codecs_hk' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/_codecs_hk.c -o build/temp.linux-x86_64-3.8/cjkcodecs/_codecs_hk.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/_codecs_hk.c: No such file or directory
 building '_codecs_iso2022' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c cjkcodecs/_codecs_iso2022.c -o build/temp.linux-x86_64-3.8/cjkcodecs/_codecs_iso2022.o
 x86_64-linux-gnu-gcc: error: cjkcodecs/_codecs_iso2022.c: No such file or directory
 building '_decimal' extension
 creating build/temp.linux-x86_64-3.8/_decimal
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DCONFIG_64=1 -DASM=1 -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _decimal/_decimal.c -o build/temp.linux-x86_64-3.8/_decimal/_decimal.o
 x86_64-linux-gnu-gcc: error: _decimal/_decimal.c: No such file or directory
 building '_multiprocessing' extension
 creating build/temp.linux-x86_64-3.8/_multiprocessing
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -IModules/_multiprocessing -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _multiprocessing/multiprocessing.c -o build/temp.linux-x86_64-3.8/_multiprocessing/multiprocessing.o
 x86_64-linux-gnu-gcc: error: _multiprocessing/multiprocessing.c: No such file or directory
 building 'ossaudiodev' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c ossaudiodev.c -o build/temp.linux-x86_64-3.8/ossaudiodev.o
 x86_64-linux-gnu-gcc: error: ossaudiodev.c: No such file or directory
 building 'xxlimited' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DPy_LIMITED_API=0x03050000 -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c xxlimited.c -o build/temp.linux-x86_64-3.8/xxlimited.o
 x86_64-linux-gnu-gcc: error: xxlimited.c: No such file or directory
 building '_ctypes' extension
 x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/usr/include/x86_64-linux-gnu -I. -IObjects -IInclude -IPython -I/usr/include/x86_64-linux-gnu -I/usr/local/include -I/usr/include/python3.8 -c _ctypes/_ctypes.c -o build/temp.linux-x86_64-3.8/_ctypes/_ctypes.o
 x86_64-linux-gnu-gcc: error: _ctypes/_ctypes.c: No such file or directory
Python build finished successfully! The necessary bits to build these optional modules were not found: _bz2 _dbm _elementtree _gdbm _lzma _sqlite3 _tkinter _uuid readline spwd To find the necessary bits, look in setup.py in detect_modules() for the module's name.
The following modules found by detect_modules() in setup.py, have been built by the Makefile instead, as configured by the Setup files: _abc _bisect _blake2 _csv _datetime _heapq _md5 _pickle _posixsubprocess _random _sha1 _sha256 _sha3 _sha512 _socket _struct array atexit binascii cmath fcntl grp math pwd pyexpat select syslog time unicodedata zlib
Failed to build these modules: _asyncio _codecs_cn _codecs_hk _codecs_iso2022 _codecs_jp _codecs_kr _codecs_tw _contextvars _crypt _ctypes _ctypes_test _curses _curses_panel _decimal _hashlib _json _lsprof _multibytecodec _multiprocessing _opcode _queue _ssl _testbuffer _testcapi _testimportmultiple _testmultiphase _xxtestfuzz audioop mmap nis ossaudiodev parser resource termios xxlimited
Could not build the ssl module! Python requires an OpenSSL 1.0.2 or 1.1 compatible libssl with X509_VERIFY_PARAM_set1_host(). LibreSSL 2.6.4 and earlier do not provide the necessary APIs, https://github.com/libressl-portable/portable/issues/381
running build_scripts creating build/scripts-3.8 error: [Errno 2] No such file or directory: '/usr/lib/python3.8/config-3.8-x86_64-linux-gnu/Tools/scripts/pydoc3'
ERROR: Failed building wheel for Python Running setup.py clean for Python Failed to build Python Installing collected packages: Python Running setup.py install for Python ... error ERROR: Command errored out with exit status 1: command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-_od32i_x/setup.py'"'"'; file='"'"'/tmp/pip-req-build-_od32i_x/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' install --record /tmp/pip-record-kzs09dnd/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/beany_lass/.local/include/python3.8/Python cwd: /tmp/pip-req-build-_od32i_x/ Complete output (6 lines): usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...] or: setup.py --help [cmd1 cmd2 ...] or: setup.py --help-commands or: setup.py cmd --help
error: option --single-version-externally-managed not recognized
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-_od32i_x/setup.py'"'"'; file='"'"'/tmp/pip-req-build-_od32i_x/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' install --record /tmp/pip-record-kzs09dnd/install-record.txt --single-version-externally-managed --user --prefix= --compile --install-headers /home/beany_lass/.local/include/python3.8/Python Check the logs for full command output.
karel
  • 122,292
  • 133
  • 301
  • 332
For newer Python I prefer the deadsnake ppa. For installing it, try this:
sudo apt install software-properties-common
sudo add-apt-repository ppa:deadsnakes/ppa
sudo apt update
sudo apt install python3.7
$ python3.7 -V
Python 3.7.7
moep
  • 564
The Python 3.7 package from the official Ubuntu 19.10 repositories can be installed in Ubuntu 20.04 without adding any new repositories to your software sources by running the following commands:
sudo apt update
wget -c http://mirrors.kernel.org/ubuntu/pool/main/libf/libffi/libffi6_3.2.1-9_amd64.deb http://security.ubuntu.com/ubuntu/pool/main/p/python3.7/libpython3.7-stdlib_3.7.5-2~19.10ubuntu1_amd64.deb http://security.ubuntu.com/ubuntu/pool/main/p/python3.7/libpython3.7-minimal_3.7.5-2~19.10ubuntu1_amd64.deb http://security.ubuntu.com/ubuntu/pool/main/p/python3.7/python3.7-minimal_3.7.5-2~19.10ubuntu1_amd64.deb http://security.ubuntu.com/ubuntu/pool/main/p/python3.7/python3.7_3.7.5-2~19.10ubuntu1_amd64.deb
sudo apt install ./libffi6_3.2.1-9_amd64.deb ./libpython3.7-minimal_3.7.5-2~19.10ubuntu1_amd64.deb ./libpython3.7-stdlib_3.7.5-2~19.10ubuntu1_amd64.deb ./python3.7-minimal_3.7.5-2~19.10ubuntu1_amd64.deb ./python3.7_3.7.5-2~19.10ubuntu1_amd64.deb
Add Python 3.7 to update-alternatives so that you can switch between Python 3.8 and Python 3.7 by running update-alternatives --config python3.
sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.8
sudo update-alternatives --install /usr/bin/python3 python3 /usr/bin/python3.7
karel
  • 122,292
  • 133
  • 301
  • 332
