When I try to install Python 3.8 terminal says it is done, but when I run python --version it says Python 3.7.
(base) user@admin:~$ sudo apt-get install python3.8
Reading package lists... Done
Building dependency tree
python3.8 is already the newest version (3.8.2-1ubuntu1.2).
The following packages were automatically installed and are no longer required:
  libllvm9 libllvm9:i386
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 38 not upgraded.
(base) user@admin:~$ python --version
Python 3.7.6
Zanna
  • 72,312
As per the instructions on How to Install Python 3.8 on Ubuntu, Debian and LinuxMint – TecAdmin, try the following:
Prerequisites:
Install [and or update] the following packages; build-essential, checkinstall, libreadline-gplv2-dev, libncursesw5-dev, libssl-dev, libsqlite3-dev, tk-dev, libgdbm-dev, libc6-dev, libbz2-dev, libffi-dev, zlib1g-dev.
sudo apt install build-essential checkinstall
sudo apt-get install libreadline-gplv2-dev libncursesw5-dev libssl-dev libsqlite3-dev tk-dev libgdbm-dev libc6-dev libbz2-dev libffi-dev zlib1g-dev
Thereafter, change directory (cd) to your opt folder [or any convenient folder] and download the python source code from python's server:
First change directory (cd) to the 'opt' folder:
cd /opt/
Download the source code
sudo wget https://www.python.org/ftp/python/3.8.3/Python-3.8.3.tgz
Extract the [downloaded] source code files
sudo tar xzf Python-3.8.3.tgz
Change directory (cd) the Python Folder [created after the extraction]
cd Python-3.8.3
Compile the source code
sudo ./configure --enable-optimizations
then
sudo make altinstall
Once the compilation is completed, you can confirm that Python 3.8 has been installed successfully with:
python3.8 -V
You should see the response Python-3.8.3.
However, to precisely answer your question, python 3.8 isn't available via ubuntu official repos. You would have to add a PPA to get python 3.8 using sudo apt install [python3.x.x].
The process is described on How to Install Python 3.8 on Ubuntu 18.04 | Linuxize
Hope this helps and I hope I answered your question adequately.
Kulfy
  • 18,154
It looks like Python 3.8 is already installed but not set as default. Python 3.7.6 is set as default.
Update default Python3 version by below command.
sudo update-alternatives --config python3
Choose Python 3.8 option and check Python version again.
KK Patel
  • 19,753
