I've recently installed Ubuntu 20.04 on my laptop only to find the touchpad didn't work, it is recognized in xinput and is turned on in settings. Which drivers can I install to make it work? (HP Pavilion 15 Gaming, Nvidia GeForce GTX 1050, AMD Ryzen 5)
Output of Xinput :
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ ETPS/2 Elantech Touchpad                  id=15   [slave  pointer  (2)]
⎜   ↳ MOSART Semi. 2.4G Keyboard Mouse Consumer Control id=11   [slave  pointer  (2)]
⎜   ↳ MOSART Semi. 2.4G Keyboard Mouse          id=18   [slave  pointer  (2)]
⎣ Virtual core keyboard                     id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ HP TrueVision HD Camera: HP Tru           id=13   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=14   [slave  keyboard (3)]
    ↳ HP Wireless hotkeys                       id=16   [slave  keyboard (3)]
    ↳ HP WMI hotkeys                            id=17   [slave  keyboard (3)]
    ↳ MOSART Semi. 2.4G Keyboard Mouse          id=9    [slave  keyboard (3)]
    ↳ MOSART Semi. 2.4G Keyboard Mouse System Control   id=10   [slave  keyboard (3)]
    ↳ MOSART Semi. 2.4G Keyboard Mouse Consumer Control id=12   [slave  keyboard (3)]
ssg-004@ssg-004-HP-Pavilion-Gaming-Laptop-15-ec0xxx:~$ xinput list-props 15 Device 'ETPS/2 Elantech Touchpad': Device Enabled (148): 1 Coordinate Transformation Matrix (150): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000 libinput Tapping Enabled (303): 1 libinput Tapping Enabled Default (304): 0 libinput Tapping Drag Enabled (305): 1 libinput Tapping Drag Enabled Default (306): 1 libinput Tapping Drag Lock Enabled (307): 0 libinput Tapping Drag Lock Enabled Default (308): 0 libinput Tapping Button Mapping Enabled (309): 1, 0 libinput Tapping Button Mapping Default (310): 1, 0 libinput Natural Scrolling Enabled (285): 1 libinput Natural Scrolling Enabled Default (286): 0 libinput Disable While Typing Enabled (311): 1 libinput Disable While Typing Enabled Default (312): 1 libinput Scroll Methods Available (287): 1, 1, 0 libinput Scroll Method Enabled (288): 0, 1, 0 libinput Scroll Method Enabled Default (289): 1, 0, 0 libinput Click Methods Available (313): 1, 1 libinput Click Method Enabled (314): 1, 0 libinput Click Method Enabled Default (315): 1, 0 libinput Middle Emulation Enabled (292): 0 libinput Middle Emulation Enabled Default (293): 0 libinput Accel Speed (294): 0.000000 libinput Accel Speed Default (295): 0.000000 libinput Left Handed Enabled (299): 0 libinput Left Handed Enabled Default (300): 0 libinput Send Events Modes Available (270): 1, 1 libinput Send Events Mode Enabled (271): 0, 0 libinput Send Events Mode Enabled Default (272): 0, 0 Device Node (273): "/dev/input/event10" Device Product ID (274): 2, 14 libinput Drag Lock Buttons (301): <no items> libinput Horizontal Scroll Enabled (302): 1
7 Answers7
Had the same issue on my HP Pavillion running Ubuntu 20.04. I spent two days looking for a solution.
The first thing that worked for me was editing the /etc/default/grub file:
GRUB_CMDLINE_LIN UX_DEFAULT="quiet splash psmouse.proto=bare"
GRUB_CMDLINE_LINUX="i8042.reset i8042.nomux i8042.nopnp i8042.noloop"
The link below has the full procedure: https://medium.com/@barcelos.ds/how-to-fix-touchpad-mouse-not-working-in-linux-operating-systems-b328bb43b4c5
After making those changes I could not use two-finger scrolling. To get that working I had to update the Linux kernel to version 5.10
The link below is what I followed to update the kernel: http://ubuntuhandbook.org/index.php/2020/12/install-linux-kernel-5-10-ubuntu-linux-mint/
Hope this helps.
This is a kind of a bug in Ubuntu 20.04 where xorg-synaptics is in use when it shouldn't be.
This can be fixed by
sudo apt remove xserver-xorg-input-synaptics
The touchpad should start working with libinput after a logoff or reboot.
Pilot6
  • 92,041
I had this problem. In the end what fixed it was upgrading the linux kernel through the HWE:
sudo apt install linux-generic-hwe-20.04
This brings in newer device drivers from the linux 5.11 kernel.
Jeff
  • 75
I found this post that said to go into the boot menu and select the linux boot and it worked for me. However, you have to do this every time you reboot.
I've been using Ubuntu since 08.04 but don't consider myself 'knowledgable' on the subject. I have noted however that I suffered the same issues with my new HP laptop when I replaced Windows10 with Ubuntu 20.04. No touchpad detected ergo just no touchpad! I recently decided to dual boot Win10 & Ubuntu but the problem persisted until today. I selected UEFI Firmware Setup from the Grub menu. This took me to Windows Boot Manager where I selected Ubuntu.This took me back to the GRUB menu where I selected Ubuntu. Hey Presto, fully functioning Touchpad with one and two finger scrolling etc. Hope this helps someone else with similar setup to gain functionality. My motive was simply to get back to Ubuntu as I tired of Windows very quickly and just wanted to come 'home'.
@user491177 i cannot add a comment bc i have not enough reputation. I just created an account for your post :D I am searching for my touchpad problem for hours and couldnt find it. I have the exact same setup like you with the dual boot. So I go from grub to boot manager, select linux and then it works :D GJ!
Sayne
The touchpad tapping is disabled by default.
To enable it do this:
  1. install xinput
sudo apt install -y xinput
  1. Getting the touchpad ID
xinput --list
You will see something like this:
⎡ Virtual core pointer                      id=2    [master pointer  (3)]
⎜   ↳ Elan Touchpad                             id=11   [slave  pointer  (2)]
⎜   ↳ Elan TrackPoint                           id=12   [slave  pointer  (2)]
⎜   ↳ ELAN Touchscreen                          id=9    [slave  pointer  (2)]
As shown example above, we can see that Elan Touchpad id is 11. It might be different on your device id 3. Now lets query available settings for the device by typing
xinput list-props 11 | head -n5
You will find something like this:
Device 'Elan Touchpad':
    Device Enabled (187):   1
    Coordinate Transformation Matrix (189): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
    libinput Tapping Enabled (320): 0
    libinput Tapping Enabled Default (321): 0
As we can see the libinput Tapping Enabled with the ID of 320 is disabled with the value of 0. To enable it we have to set the value to 1 by typing:
xinput set-prop 11 320 1
Explanations as follow:
  • set-prop sets a property for an input device
  • 11 is the identifier for the touchpad device
  • 320 is the switch identifier for enabling and disabling the libinput Tapping
  • 1 specifies the enable option for libinput Tapping
Refference: How to enable/disable touchpad
JoenMarz
  • 117
