I'm trying to upgrade my Ubuntu from version 18.04 to version 20.04. When I run sudo apt udate I receive the following error:
N: Skipping acquire of configured file 'universe/binary-i386/Packages' as repository 'https://repos.codelite.org/ubuntu bionic InRelease' doesn't support architecture 'i386'
I also cannot update to Ubuntu 20 when I run sudo update-manager -d and I receive the following error:
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
update: The first error was resolved! But I still cannot update to Ubuntu 20. when I run sudo apt update, I get:
Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:4 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:5 https://repos.codelite.org/ubuntu bionic InRelease
Hit:6 http://archive.ubuntu.com/ubuntu bionic-security InRelease
Hit:7 https://packages.microsoft.com/ubuntu/18.04/prod bionic InRelease
Hit:8 https://cloud.r-project.org/bin/linux/ubuntu bionic-cran35/ InRelease
Get:9 https://desktop-download.mendeley.com/download/apt stable InRelease [2,456 B]
Hit:10 http://ppa.launchpad.net/plushuang-tw/uget-stable/ubuntu bionic InRelease
Hit:11 http://ppa.launchpad.net/smathot/cogscinl/ubuntu bionic InRelease
Hit:12 http://ppa.launchpad.net/uget-team/ppa/ubuntu bionic InRelease
Fetched 2,456 B in 2s (1,396 B/s)
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
When I run sudo apt upgrade, I get:
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Following the note from update, I run apt list --upgradable and the output is
python-datamatrix/bionic,bionic 0.10.17-1 all [upgradable from: 0.10.3-1]
The default Python version on mu Ubuntu is Python 3.6.9
For the first problem, refer to the answer Skippping acquire configured file - doesn't support architecture 'i386' You must find the file located in /etc/apt where the string 'repos.codelite.org' is present and add the string '[arch=amd64]'. In this way only the packages for the correct architecture are installed.
For the second problem (the one related to the OS updated), according to the output you showed in your question, I suggested you to update the package python-datamatrix running: pip3 install python-datamatrix
However, according to your feedback (you were not able to solve), it's best to remove it (as suggested in karel's answer): pip3 uninstall python-datamatrix
For this answer, I referred also to Error while trying to upgrade from Ubuntu 18.04 to 18.10: "Please install all available updates for your release before upgrading." and Can't upgrade Ubuntu 18.04 to 20.04 because of "Please install all available updates for your release before upgrading" error
Lorenz Keel
  • 9,511
Uninstall python-datamatrix with sudo apt remove python-datamatrix as it is blocking you from upgrading to Ubuntu 20.04. Then you will be able to run update-manager -d.
python-datamatrix source code is hosted at GitHub. python-datamatrix can be installed in Ubuntu 20.04 with the following commands:
sudo apt update
sudo apt install python2.7 python-pip
python -m pip install python-datamatrix
python-datamatrix is compatible with Python 2.7 or >= 3.4. If you don't want to install Python 2.7 you can also install it with the following commands:
sudo apt update
sudo apt install python3-pip
python3 -m pip install python-datamatrix
karel
  • 122,292
  • 133
  • 301
  • 332
