I have Ubuntu 20.04 (recently upgraded from 19.10) running on my ThinkPad T420 and since a couple of days I have the issue that Ubuntu stops startup at a screen that just shows
/dev/mapper/ubuntu--vg-root: clean, 1737827/15081472 files, 51603057/60309504 bl
ocks
_
and a flashing prompt in the next line.
There's no error message, the prompt doesn't accept any input, no reaction on special keys like Esc, F keys, Strg + C, Enter, ... If I wait, nothing else happens.
When it happened first, after a couple of power-off/boot cycles the Ubuntu login screen came up. So it seeemed like a random annoyance. But since a reboot (after some updates) I had to do yesterday, I'm out of luck. Boot stops at this screen everytime I try.
I found tons of advice on how to fix different kinds of issues with /dev/mapper/ubuntu--vg-root (Ubuntu boots into busybox, Ubuntu boots into initramfs, ...) but all of those issues come with related error messages that give a hint what's wrong. None of them fit my issue exactly. So I randomly tried a couple of suggestions that seemed appropriate to get more information about the issue and possible fixes, but with no luck so far.
So I hope one of you knows more abbout that issue and can help me to fix it.
What I tried on the system:
- change boot options UEFI/BIOS --> apparently my system boots from BIOS
- update grub --> no error, but doesn't fix the issue
- fsck --> tells me that /dev/mapper/ubuntu--vg-root is mounted and e2fsck can't continue
- drop to root shell and try to upgrade LVM2 via
sudo apt update && sudo apt upgrade lvm2--> tells me that the current version (2.03.07-1ubuntu1) is already installed
removed the SSD and put it back in (to rule out a connection issue) --> didn't help
Then I booted from a live stick and tried the following:
mount /dev/mapper/ubuntu--vg-root /mntworks and I can access the file system, so apparently it's not an encrypted partition as many posts say. I was able to do a full backup of my home directory to an external USB drive (yay!)udisksctl unlock -b /dev/sda5confirms that the partition is not encrypted --> "Object /org/freedesktop/UDisks2/block_devices/sda5 is not an encrypted device."- tried to re-install grub --> didn't fix the issue
- Tried to do fsck (see note below) --> didn't fix the issue
- tried to re-install Ubuntu following this guide, but I didn't get the re-install option that wouldn't overwrite the whole disk. **Does anyone know how to enforce the "re-install" option if it doesn't show up?*
- I was able to run a file system check with 'gnome-disks' which reported that the extra file system on /dev/ubuntu-vg/root was fine
During my experiments there was one thing that caught my eye:
I did fsck /dev/mapper/ubuntu--vg-root from the live stick:
ubuntu@ubuntu:~$ sudo su
root@ubuntu:/home/ubuntu# fsck /dev/mapper/ubuntu--vg-root
fsck from util-linux 2.34
e2fsck 1.45.5 (07-Jan-2020)
/dev/mapper/ubuntu--vg-root: clean, 1737833/15081472 files, 51605368/60309504 blocks
It gives the same output as ubuntu shows when it hangs during boot. So I assume that Ubuntu gets stuck while doing fsck on startup. But why?
May it be possible that this is not an issue with ubuntu-vg-root, but with whatever comes after it during the boot process? How do I find out what would come next?
I hope one of you guys knows more about this stuff and can give me a hint.
Thanks in advance Fred
