Hello Ubuntu community,
I have Ubuntu 18.04.4 LTS on a Asus ZenBook UX303LB and face a seeming system freeze directly after entering my user password. The password dialog disappears thus only the purple background of the login page together with my mouse pointer remain visible. This problem does not occur if Ubuntu with Wayland is selected before logging in.
I opened the TTY3 during seeming system freeze and get the following messages repeating over and over again.
[3434.281062] EXT4-fs (sda7): ext4_writepages: jbd2_start: 13312 pages, ino 262223; err-30
[...] systemd-journald[328]: Failed to write entry (21 items, 604 bytes), ignoring: Read-only file system
Output of df -h is as follows:
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
udev 3,9G 0 3,9G 0% /dev
tmpfs 787M 2,1M 785M 1% /run
/dev/sda7 28G 18G 8,8G 67% /
tmpfs 3,9G 0 3,9G 0% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
/dev/loop1 1,0M 1,0M 0 100% /snap/gnome-logs/93
/dev/loop2 384K 384K 0 100% /snap/gnome-characters/550
/dev/loop3 114M 114M 0 100% /snap/blender-tpaw/3
/dev/loop4 162M 162M 0 100% /snap/gnome-3-28-1804/128
/dev/loop5 256K 256K 0 100% /snap/gtk2-common-themes/5
/dev/loop6 1,0M 1,0M 0 100% /snap/gnome-logs/100
/dev/loop7 114M 114M 0 100% /snap/audacity/666
/dev/loop9 141M 141M 0 100% /snap/gnome-3-26-1604/100
/dev/loop8 2,5M 2,5M 0 100% /snap/gnome-calculator/730
/dev/loop0 78M 78M 0 100% /snap/viking-gps/18
/dev/loop11 256M 256M 0 100% /snap/gnome-3-34-1804/36
/dev/loop10 384K 384K 0 100% /snap/gnome-characters/539
/dev/sda6 1,9G 170M 1,6G 10% /boot
/dev/loop12 55M 55M 0 100% /snap/core18/1754
/dev/sda3 96M 31M 66M 32% /boot/efi
/dev/loop13 2,3M 2,3M 0 100% /snap/gnome-system-monitor/145
/dev/loop14 106M 106M 0 100% /snap/audacity/648
/dev/loop16 63M 63M 0 100% /snap/gtk-common-themes/1506
/dev/loop15 49M 49M 0 100% /snap/gtk-common-themes/1474
/dev/loop17 55M 55M 0 100% /snap/core18/1705
/dev/loop18 256M 256M 0 100% /snap/gnome-3-34-1804/33
/dev/sda8 125G 114G 4,8G 96% /home
/dev/loop20 94M 94M 0 100% /snap/core/9066
/dev/loop19 256K 256K 0 100% /snap/gtk2-common-themes/9
/dev/loop21 98M 98M 0 100% /snap/core/9289
/dev/loop22 161M 161M 0 100% /snap/gnome-3-28-1804/116
/dev/loop23 141M 141M 0 100% /snap/gnome-3-26-1604/98
/dev/loop24 182M 182M 0 100% /snap/spotify/36
/dev/loop25 2,5M 2,5M 0 100% /snap/gnome-calculator/748
/dev/loop26 164M 164M 0 100% /snap/spotify/41
/dev/loop27 2,3M 2,3M 0 100% /snap/gnome-system-monitor/148
tmpfs 787M 16K 787M 1% /run/user/121
tmpfs 787M 1,4M 786M 1% /run/user/1000
Removing .cache folder and using sudo apt clean together with executing sudo fsck.ext4 /dev/sda7 made the file system error messages disappear. Unfortunately the seeming system freeze remains.
The login using TTY seems to work. May the fact that Ubuntu works fine when selecting Ubuntu with Wayland be a hint for the problems origin? Are there logs I can provide to make the solution finding process easier?
