I have recently increased the size of my Ubuntu /home directory and reinstalled both Windows and Ubuntu on my Lenovo Legion Y540 laptop. Installation went smoothly, but since then I have noticed that my laptop gets significantly hot (palpable on keyboard) even when simply web browsing. I have installed lm-sensors to check the temperature of my CPU and straight after booting Ubuntu, temperatures were as follows:
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +66.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +66.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +64.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +66.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +63.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +63.0°C (high = +100.0°C, crit = +100.0°C)
Core 5: +62.0°C (high = +100.0°C, crit = +100.0°C)
At the time of writing this post I have only a dozen or so Firefox tabs enabled and the temperature are as below:
coretemp-isa-0000
Package id 0: +85.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +85.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +79.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +85.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +81.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +85.0°C (high = +100.0°C, crit = +100.0°C)
Core 5: +81.0°C (high = +100.0°C, crit = +100.0°C)
Therefore, I am concerned to do any computing as those temperatures would certainly go even higher. I have had this laptop for about 6 months and I didn't observe this significant keyboard heat before. Any ideas what may be causing this issue and what I should change to prevent it?
I'll be happy to provide any additional information.
I worked on Windows for a couple of minutes. I don't know how can I measure the CPU temperature on Windows, but palpably, the issue was absent there.
I switched to Intel GPU as advised by @heynnema, the current output of sensors is:
coretemp-isa-0000
Package id 0: +84.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +76.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +75.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +76.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +80.0°C (high = +100.0°C, crit = +100.0°C)
Core 5: +77.0°C (high = +100.0°C, crit = +100.0°C)
Whereas the output of ps auxc | grep -i therm. is:
root 210 0.0 0.0 0 0 ? I< cze07 0:00 acpi_thermal_pm
root 884 0.0 0.0 188224 9644 ? Ssl cze07 0:00 thermald
@Edit: systemctl status thermald output is:
● thermald.service - Thermal Daemon Service
Loaded: loaded (/lib/systemd/system/thermald.service; enabled; vendor preset:
Active: active (running) since Mon 2020-07-20 08:29:43 CEST; 12h ago
Main PID: 995 (thermald)
Tasks: 2 (limit: 4915)
CGroup: /system.slice/thermald.service
└─995 /usr/sbin/thermald --no-daemon --dbus-enable
lip 20 08:29:43 jakes systemd[1]: Starting Thermal Daemon Service...
lip 20 08:29:43 jakes systemd[1]: Started Thermal Daemon Service.
lip 20 08:29:43 jakes thermald[995]: 22 CPUID levels; family:model:stepping 0x6:9
lip 20 08:29:43 jakes thermald[995]: Polling mode is enabled: 4
lip 20 08:29:43 jakes thermald[995]: sysfs read failed constraint_0_max_power_uw
