I have a AX200 wifi adapter from Ubit (link) that I'm trying to use on an 18.04 ubuntu install with kernel 4.15. I can't update the kernel because of needing proper CUDA support, so I've followed the advice here and elsewhere to install the backported iwlwifi driver. I've also installed the iwlwifi-cc-a0-46 firmware from Intel.
Operating system sees the wifi adapter, everything seems hunky-dory until I actually go to connect to my wireless network. I enter my password, click "connect" and then everything freezes. Please help! Here are some diagnostic messages, let me know what else would be helpful:
rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
dmesg | grep iwlwifi
[ 11.040689] Loading modules backported from iwlwifi
[ 11.040689] iwlwifi-stack-public:master:8613:3ae69204
[ 11.097569] iwlwifi 0000:02:00.0: enabling device (0100 -> 0102)
[ 11.104708] iwlwifi 0000:02:00.0: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
[ 11.104848] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-57.ucode failed with error -2
[ 11.104857] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 11.104863] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-55.ucode failed with error -2
[ 11.104868] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-54.ucode failed with error -2
[ 11.104873] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-53.ucode failed with error -2
[ 11.105479] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-52.ucode failed with error -2
[ 11.105492] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-51.ucode failed with error -2
[ 11.105500] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 11.105507] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 11.105515] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-48.ucode failed with error -2
[ 11.105523] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-47.ucode failed with error -2
[ 11.110659] iwlwifi 0000:02:00.0: loaded firmware version 46.3cfab8da.0 cc-a0-46.ucode op_mode iwlmvm
[ 11.110675] iwlwifi 0000:02:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 11.130761] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 11.291742] iwlwifi 0000:02:00.0: base HW address: 4c:1d:96:ba:ba:67
[ 11.307461] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
lspci -nnk | grep -A2 0280
02:00.0 Network controller [0280]: Intel Corporation Device [8086:2723] (rev 1a)
Subsystem: Intel Corporation Device [8086:0084]
Kernel driver in use: iwlwifi
modprobe -v backport-iwlwifi
modprobe: FATAL: Module backport-iwlwifi not found in directory /lib/modules/4.15.0-101-generic
uname -sr
Linux 4.15.0-101-generic
Any suggestions?
Update June 11, 2020:
I think the issue is probably pointed to by this sequence of statuses from gnome-system-log, but I'm not able to fully parse them myself:
Jun 11 18:02:36 DendriteDesktop NetworkManager[1117]: <info> [1591923756.0240] device (wlp2s0): Activation: starting connection 'PalaceMesh' (137d3860-14ad-42c0-b931-c7223a817175)
Jun 11 18:02:36 DendriteDesktop NetworkManager[1117]: <info> [1591923756.0244] audit: op="connection-activate" uuid="137d3860-14ad-42c0-b931-c7223a817175" name="PalaceMesh" pid=3673 uid=1000 result="success"
Jun 11 18:02:36 DendriteDesktop NetworkManager[1117]: <info> [1591923756.0250] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 11 18:02:36 DendriteDesktop NetworkManager[1117]: <info> [1591923756.0261] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 11 18:02:36 DendriteDesktop NetworkManager[1117]: <info> [1591923756.0270] device (wlp2s0): Activation: (wifi) access point 'PalaceMesh' has security, but secrets are required.
Jun 11 18:02:36 DendriteDesktop NetworkManager[1117]: <info> [1591923756.0270] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jun 11 18:02:40 DendriteDesktop org.gnome.Shell.desktop[2816]: Window manager warning: Overwriting existing binding of keysym 73 with keysym 73 (keycode 27).
Jun 11 18:02:51 DendriteDesktop NetworkManager[1117]: <warn> [1591923771.2563] device (wlp2s0): User canceled the secrets request.
Jun 11 18:02:51 DendriteDesktop NetworkManager[1117]: <info> [1591923771.2564] device (wlp2s0): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Jun 11 18:02:51 DendriteDesktop NetworkManager[1117]: <warn> [1591923771.2572] device (wlp2s0): Activation: failed for connection 'PalaceMesh'
Jun 11 18:02:51 DendriteDesktop NetworkManager[1117]: <info> [1591923771.2580] device (wlp2s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jun 11 18:02:51 DendriteDesktop gnome-shell[1817]: An active wireless connection, in infrastructure mode, involves no access point?
Jun 11 18:02:51 DendriteDesktop kernel: [ 643.060538] IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
Jun 11 18:02:51 DendriteDesktop gnome-shell[2816]: An active wireless connection, in infrastructure mode, involves no access point?
Jun 11 18:02:55 DendriteDesktop gnome-control-c[3673]: g_variant_unref: assertion 'value != NULL' failed
Jun 11 18:02:55 DendriteDesktop dbus-daemon[1066]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.127' (uid=1000 pid=3673 comm="gnome-control-center " label="unconfined")
Jun 11 18:02:55 DendriteDesktop systemd[1]: Started Run anacron jobs.
Jun 11 18:02:55 DendriteDesktop systemd[1]: Starting Hostname Service...
Jun 11 18:02:55 DendriteDesktop anacron[4337]: Anacron 2.3 started on 2020-06-11
Jun 11 18:02:55 DendriteDesktop anacron[4337]: Normal exit (0 jobs run)
Jun 11 18:02:55 DendriteDesktop gvfsd[2793]: mkdir failed on directory /var/cache/samba: Permission denied
Jun 11 18:02:55 DendriteDesktop kernel: [ 647.366974] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
Jun 11 18:02:55 DendriteDesktop dbus-daemon[1066]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jun 11 18:02:55 DendriteDesktop systemd[1]: Started Hostname Service.
Jun 11 18:02:56 DendriteDesktop gvfsd[2793]: mkdir failed on directory /var/cache/samba: Permission denied
Jun 11 18:03:15 DendriteDesktop gvfsd[2793]: message repeated 39 times: [ mkdir failed on directory /var/cache/samba: Permission denied]
Jun 11 18:03:16 DendriteDesktop NetworkManager[1117]: <info> [1591923796.0549] device (wlp2s0): Activation: starting connection 'PalaceMesh' (137d3860-14ad-42c0-b931-c7223a817175)
Jun 11 18:03:16 DendriteDesktop NetworkManager[1117]: <info> [1591923796.0551] audit: op="connection-activate" uuid="137d3860-14ad-42c0-b931-c7223a817175" name="PalaceMesh" pid=3673 uid=1000 result="success"
Jun 11 18:03:16 DendriteDesktop NetworkManager[1117]: <info> [1591923796.0555] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jun 11 18:03:16 DendriteDesktop NetworkManager[1117]: <info> [1591923796.0566] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jun 11 18:03:16 DendriteDesktop NetworkManager[1117]: <info> [1591923796.0570] device (wlp2s0): Activation: (wifi) access point 'PalaceMesh' has security, but secrets are required.
Jun 11 18:03:16 DendriteDesktop NetworkManager[1117]: <info> [1591923796.0571] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jun 11 18:03:16 DendriteDesktop gvfsd[2793]: mkdir failed on directory /var/cache/samba: Permission denied
lines above such as
seem to suggest that Network Manager is unable to authenticate (even though I am providing the correct password) and there seems to be a repeated mkdir /var/cache/samba which is failing. I'm not sure why this should be causing my system to COMPLETELY freeze though. The contents of my iwlwifi modprobe config file are:
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system. When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
Please, does anyone have a clue what's going on?
