  • Environment: Fresh installation of Ubuntu 20.04 on Dell Inspiron 5567 laptop.
  • Related softwares installed: VLC and FFmpeg installed (haven't had any problems with these)
  • Problem: Sound doesn't come out of the earphones.
  • Recent changes to the system: Installed ubuntu-restricted-extras.
  • Further details: Sound works on in-built speakers. On earphones, when sound supposed to come there's a one-time faint pop sound comes. And that's it. It detects as headphone and shows it emits sound on settings and it shows sounds are working on the scale. [image attached]
  • Special note: Everything works normally and sounds working on same earphones, same laptop on Ubuntu 20.04 live session.
  • Tried solutions: Removing ubuntu-restricted-extras didn't fix the problem. Tried to fix it on alsamixer no luck. pulseaudio shows the same results as the sound settings shows.
PS: Reinstalling the OS isn't an option right now.
Attached: Screenshot of the sound settings
Nipuna
  • 223
for a temporary fix Run
alsactl restore
after plugging in headphones
to make it persistent so it survives a reboot run
sudo alsactl store
ptetteh227
  • 2,044
Install "pulseaudio volume control"
sudo apt install pavucontrol
Launch it from menu or using "pavucontrol" command.
  • In "pulseaudio volume control" configuration tab, check "profile" is analog.
    In output device tab, test changing port to "headphone" or "speaker". Click the green button near "internal audio" .
    2 commands to reset pulseaudio config:
    mv .config/pulse .config/pulsebak
    killall pulseaudio
  • In alsamixer, check that "headphone" and "speaker" faders are muted and unmuted when connecting/disconnecting jack.
  • Another post indicates this fix : disable audio in bios, then enable again
  • if dualboot, disable fastboot in windows.
laugeo
  • 2,880
  • 14
I updated to ubuntu focal fossa 20.04 from 18.04 and suddenly the sound and the mic stopped working.
As I am a beginner , I wasn't able to make correct changes in the alsa mixer . The other solutions in this post didn't work for me.
So, I use the following command to add the GUI version of the alsa tools. This can be done by the following commands:
sudo apt install alsa-tools-gui
hdajackretask
after this use the override option corresponding to the headphone and check the override option and apply changes.
If it works now, again reboot and check. In case , it doesn't work after reboot, you can use the Install boot override.
Amish
