My setup before: SSD-1 containing windows 10 with all of its recovery etc. partitions SSD-2 empty HDD-1 containing ubuntu 20.04 root directory + grub partition HDD-2 containing /home directory, which I mounted
My goal: SSD-1: as is SSD-2: ubuntu root + grub HDD-1: format for windows HDD-2: leave as is
What I did: 1. Copied the ubuntu root partition to SSD-2 using the bash script found here: Bash script to backkup/clone Ubuntu to another partition -> this seemingly worked after adding /home/* to --exclude={/dev/,/proc/,/sys/,/tmp/,/run/,/mnt/,/media/*,/lost+found}
After rebooting, the root directory was on the desired SSD and my /home was still mounting correctly. At this point nothing seems to be broken.
I decided (in my infinite wisdom) that since it seems to work without the old root directory being mounted, that I could delete its data, which left me in the following state.
SSD-1 Windows 10 SSD-2 Ubuntu root HDD-1 grub partition (old root was deleted here) HDD-2 Ubuntu /home
- Now on reboot I get the grub error message: error: no such device: 2f09eae6-...-...-...-... error: unknown filesystem. Entering rescue mode... grub rescue>
I would like to have my grub on the same SSD as my root directory and I would prefer if it worked again :). I have tried using my Ubuntu live USB to perform the steps described here Boot error > no such device: grub rescue, but ran into this GPT partition contains no BIOS Boot Partition.
I think I am going at this issue in the wrong way, what would be the correct approach. Is reinstalling ubuntu and then somehow mounting my root and /home the correct approach?
Thanks for any help that I receive!
