The output of anything I record from my system sound using portaudio or parec is very low in volume.
With a maximum volume as -49dB when seen using ffmpeg -i video.avi -af "volumedetect" -vn -sn -dn -f null /dev/null from this answer.
I've spotted the issue to be this
This is the output of
pactl list sources
Source #0
State: SUSPENDED
Description: Monitor of Built-in Audio Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 6
Mute: no
Volume: front-left: 9995 / 15% / -49.00 dB, front-right: 9995 / 15% / -49.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0xd52b0000 irq 132"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:00:1f.3"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "9d71"
device.form_factor = "internal"
device.string = "0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Formats:
pcm
As you can see front-left: 9995 / 15% / -49.00 dB, front-right: 9995 / 15% / -49.00 dB I need them both to be 100% I've tried pactl set-sink-vloume 0 100% but it does nothing.
I've also tried https://askubuntu.com/a/1206159/971923.
What is the commands to change the left and right both to a 100%?
I don't see those on alsamixer as well.
Using Ubuntu 20.04
I believe the os has nothing to do with the question (I'm asking for a command specific to pactl or related software like alsamixer).
