I write in french and I code in english. Is there a command to easily toggle between these two keyboard layout?
I could not find any other than setxkbmap or other similar command, but I would need to write a script to query current layout and depending on the layout, switch to the appropriate layout. Is there a better way?
Thanks!!
You can toggle smoothly between two keyboard layouts with the help of some combination of keyboard keys:
  • Key for go forward in layout list => Super+Space.
  • Key for go backward in layout list => Shift+Super+Space.
If this don't work, check the following setting. If it's not setup, then set this according to the following steps:
  1. Open the Activities overview and start typing Settings.
  2. Click on Settings.
  3. Click Region & Language in the sidebar to open the panel.
  4. Click the + button in the Input Sources section, select the language which is associated with the layout, then select a layout and press Add.
For more information you can take help of given link: https://help.ubuntu.com/stable/ubuntu-help/keyboard-layouts.html.en
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
