sudo apt update
Hit:1 http://pl.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://pl.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu focal InRelease
Hit:5 http://pl.archive.ubuntu.com/ubuntu focal-backports InRelease
Reading package lists... Done
Building dependency tree
1 package can be upgraded. Run 'apt list --upgradable' to see it.
Listing... Done
libgegl-0.4-0/focal 1:0.4.18+om-0ubu20.04.18~ppa amd64 [upgradable from: 0.4.22-3]
N: There is 1 additional version. Please use the '-a' switch to see it
apt list --upgradable -a
Listing... Done
libgegl-0.4-0/focal,now 0.4.22-3 amd64 [installed,upgradable to: 1:0.4.18+om-0ubu20.04.18~ppa]
sudo apt install libgegl-0.4-0
 libgegl-0.4-0 : Depends: libopenexr23 but it is not installable
sudo apt install libopenexr23
Package libopenexr23 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libopenexr24:i386 libopenexr24
E: Package 'libopenexr23' has no installation candidate
libgegl-0.4-0 can be upgraded but cant ? I am on Kubuntu 20.04
Q00
  • 249
sudo apt install ppa-purge && sudo ppa-purge ppa:otto-kesselgulasch/gimp
This seems to fix it
N0rbert
  • 103,263
Q00
  • 249
The following command will work: sudo apt install libopenexr-dev
Priyank
  • 2,280
