I have this issue when I search to install Gimp:
$ sudo apt-get install gimp
Reading package lists... Done
Building dependency tree
gimp : Depends: libgimp2.0 (>= 2.10.18) but it is not going to be installed
Depends: libgimp2.0 (<= 2.10.18-z) but it is not going to be installed
Depends: libgegl-0.4-0 (>= 0.4.22) but it is not going to be installed
Nothing change after apt update & upgrade. Do you have a solution for me? Thanks to
Best,
